Different sensors get identical [codes...
  • Different sensors get identical [codes...
    I have just added three more DS18S20 sensors to my system and noticed that I got the same sensor code assigned to two of them (the plugin can see all of the sensors but in HS one is missing).
    I erased EPROM on my TEMP08, flushed all sensors in the plugin, deleted devices in HS, restarted everything and got the situation worse.
    Now I have only four (4) Ultra codes assigned to all of my seven (7) sensors - see screenshots.
    HomeSeer, of course, shows four sensors only now - 3 sensors are missing.
    Just to make sure that my hardware is OK I ran HyperTerminal and TEMP08 works fine reading all 7 sensors:
    THU 09:51:52
    Reading Sensors...
    Humidity #01[9D000000B6591326]=34%
    Voltage #00=01.13V
    Voltage #01[570000004CDDD626]=00.93V 05.14V
    Temp #01[9D000000B6591326]=23.00C
    Temp #02[BF0008017F31CC10]=19.25C
    Temp #03[240008018A4F6710]=07.25C
    Temp #04[570000004CDDD626]=23.25C
    Temp #05[9D0008018A28E910]=21.68C
    Temp #06[020008017F27E910]=20.25C
    Temp #07[4A0008018A21E610]=19.62C
    (Ultra1Wire version 1.1.3319.26115, HS 2.3.0.0)
    Hope for quick responce. Thank you, Alex
    P.S. - the sensors names look interesting in chart - with two brackets now [[
      I'll look into this.
      You can quickly fix the issue by:
      • Deleting the HSPI Ultra1wire HomeSeer devices.
      • Shutdown HomeSeer.
      • Renaming the hspi_ultra1wire.ini file in the HomeSeer Config directory.
      • Restart HomeSeer.
      • Set up com port again for TEMP08.
      The plug-in should re-create them.
      Ultrajones
        That fix did not work for me.
        I understand the idea and I believe it should be working but I must have done something wrong. You did not mention if I should delete 1-wire devices in the HS interface but I did delete both in HS and in the plugin. So, the HS never found any sensors after restarting (the patient did not recover after the brain surgery).
        I had to restore my HS folder from January backup files. All of the sensors came up fine but I believe if I would ever disconnect and reconnect any of them I will run into the same mess again.
        Alex
          Okay, I'll dig into this tomorrow to see if I can duplicate it.
