This plug-in is working fine, but I have a couple of questions about using the values in messages (text or email). I was trying to generate a pushover message when certain temperature measurements are outside certain parameters. I wanted the message to contain a brief warning and the temperature in question. The first problem is using the Replacement Variable $$DVA will not work because the addresses generated by the plug-in contains colons e.g. "6400000565E19B28:T:A" so the device cannot be found by address. There are no device codes generated so $$DVC wont work until I assign a code and when I create one, the plug-in creates a new device leaving the modified one in place, but no longer active the next time HS starts up. $$DVR does work.
A couple of questions about device values
HomeSeer Tech seems uninterested in fixing the issue with colons in device addresses, so I'll need to release an update to remove them. I hope to have it released within the next few days.
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
