Error message
  • Error message
    I have just upgraded to HS3 and in doing so I downloaded the Plug-in ULTRA1WIRE3. To connect my Temp08 to HS3 (before on HS2 ran the script which came with the controller.
    The program has found all the Temperature sensors but not the Switch IC's.
    All I seam to be getting is the Error message below. Can anyone Help?
    System.ArgumentException: parsing "Switch #(?\d\d)\[(?.*)\]=?(On|Off))" - Too many )'s. at System.Text.RegularExpressions.RegexParser.ScanRegex() at System.Text.RegularExpressions.RegexParser.Parse(String re, RegexOptions op) at System.Text.RegularExpressions.Regex..ctor(String pattern, RegexOptions options, Boolean useCache) at HSPI_ULTRA1WIRE3.TEMP08.ProcessOneWireSwitch(String strRecData)
    Ultra1Wire3 HSPI version 3.0.6510.21140 was just posted that fixes the issue you reported.
    Ultrajones
