Ultra1Wire3 not detecting my HA7E
    1-Wire Interface Adapters
    HA7E: 0
    how do i debug this? what log settings can i use to get some help with this?
    When i use putty to COM4 (which is where the interface is connected) i do get responses to commands)
    Mark
    HS3 Pro 4.2.19.5
    Guys,
    this is still not working. when i enable debug logging, and restart the plugin, there is nothing useful in the .log file. the plugin doesn't even look like its attempting to contact the comport connected to the HA7E
    suggestions welcome
    Mark
    HS3 Pro 4.2.19.5
      still looking for feedback
      Mark
      HS3 Pro 4.2.19.5
        Jones,
        Can you help me out here a little. the plugin isn't seeing the HA7E
        Mark
        HS3 Pro 4.2.19.5
          Hello mnsandler,
          I am sorry for the delay in responding. I just blew the dust off of my EDS HA7E and manually added it to COM:3 and the plug-in detected it along with the connected temperature sensors. Can you provide a screenshot of the devices web page? Can you also tell me what type of temperature sensors you have connected?
          Ultrajones
            Jones
            I have 8 standard ds1820 temperature sensors
            Everything was working for months until 5/31/2018 and now nothing. I haven't changed anything related to the 1-wire setup.
            I'm looking for some log entries to help me debug, but the plugin doesn't log much (or i'm missing something) regarding connecting to the HA7E on startup
            I would like to know if the ha7e is still working? how can i test manually
            Mark
            HS3 Pro 4.2.19.5
              If you connect to the serial port using PuTTY and type S, do you get a ROM code back?
              https://www.embeddeddatasystems.com/...erMan-HA7E.pdf
                with putty, when i send S i get a string of zeros back. the below is a copy of the session
                S0000000000000000
                Mark
                HS3 Pro 4.2.19.5
                  Here is a Debug log file. the plugin is sending and receiving data but i don't see any device IDs that match mine
                  Mark
                  HS3 Pro 4.2.19.5
                    Can you connect just 1 temperature sensors and try again?
                      Thanks. I tried this and still the same results. i also tried a second sensor by itself.
                      the plugin Status screen doesn't show 1 for the HA7E adapters. What is the plugin expecting back from the adapter?
                      i need to understand if the problem is the adapter , the network wiring, or a bad sensor. So i need to know if the adapter is working at all by itself.
                      Mark
                      HS3 Pro 4.2.19.5
                        So i'm still stuck. any more suggestions for diagnosing the Adapter
                        Mark
                        HS3 Pro 4.2.19.5
                          I would reach out the the vendor at https://eds.zendesk.com/hc/en-us/requests/new
                          Ultrajones
                            So I uess my HA7E is dead. Normally there should be ~5V between the DQ and GND line. I get less than 0.5V
                            Mark
                            HS3 Pro 4.2.19.5
                              I'm switching to the TEMP08. Will I need to redo my existing hs devices for the temp sensors i already have registered in the plugin?
                              Mark
                              HS3 Pro 4.2.19.5
