no chart
    no chart
    hi
    Controler HA7E is OK, device DS18B20 is ok, but I have no chart. It is a new install. my javascript is OK and enable on CHROME.
    log:
    août-16 22:53:23 Error La valeur ajoutée ou soustraite résulte en un DateTime qui ne peut pas être représenté. Nom du paramètre : value
    debug:
    hspi_ultra1wire3_debug.txt
    thank you for you help.
    Current Date/Time: 16/08/2019 22:27:38
    HomeSeer Version: HS3 Pro Edition 3.0.0.435
    Operating System: Microsoft Windows 7 Embedded Standard - Work Station
    System Uptime: 0 Days 20 Hours 25 Minutes 14 Seconds
    IP Address: 192.168.1.16
    Number of Devices: 75
    Number of Events: 35
    Available Threads: 100
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed:
    Enabled Plug-Ins
    3.0.0.56: DSC Security
    3.9.610.5: HSBuddy
    3.3.5.17921: SMS-Gateway
    3.0.6629.22233: Ultra1Wire3
    3.0.1.249: Z-Wave
    Something odd is going on. You have over 90 database insert failures. Can you try shutting down HomeSeer, then locating and renaming the ultra1wire3.db3, then restarting HomeSeer?
      Hi,
      I turn off homeseer
      I delete all "ultra1wire3.db3" i found in \\HS3-WIN7\HomeSeer HS3\Data\ultra1wire3
      I create en new empty file name "ultra1wire.db3"
      I turn on homeseer
      I add new devices
      if i put COM5 or COM:5 it is work OK and same! is it normal?
      Click image for larger version  Name:	Capture3.JPG Views:	0 Size:	11.3 KB ID:	1321503
      I have same failures
      in \\HS3-WIN7\HomeSeer HS3\Data\ultra1wire3 I see now 2 files:
      ultra1wire3.db3 anb ultra1wire3_21.db3
      debug:
      When i do plugin charts, no chart and log say:
      août-17 20:55:46 Warning File does not exist: C:\Program Files\HomeSeer HS3\html\hspi_ultra1wire3\images\ajax-loader.gif
      août-17 20:54:42 Error La valeur ajoutée ou soustraite résulte en un DateTime qui ne peut pas être représenté. Nom du paramètre : value
      same issues
      thank you for your help
        Yes, COM:5 is the correct format. The debug logs indicate an issue with your regional date/time settings. The errors indicate the date/time cannot be properly converted using your regional settings.
        I don't have a windows 7 embedded system to test with. What regional settings are you using?
        Ultrajones
