Hi all,
I need a device that has two thermometer probes and can talk to the HS3 box about 20 feet away (two floors down in the basement). Power is no problem, but running a wire for the data would be hard, so i need wireless. I see references to TEMP06, HA7E and MN-ENV-H-THX, but I don't want to buy something that won't work. Any suggestions?
I have a recirculating pump for instant hot water and i can't get the pump on the same time the valve is open. I figured that if i put a thermometer probe on the hot and cold sides of the valve, I would be able to see when to turn the pump on (hot side below 95 degrees), and when to turn off the pump (temperature on cold side stops rising).
Thanks for your help,
Joe
Joe
