Errors logged
    Errors logged
    System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRA1WIRE3.DS18B20.ScratchPad.calcTemperature(Boolean Farenheight) at HSPI_ULTRA1WIRE3.HS_HA7E.CheckDS18B20(Int32 deviceId)
    I'm seeing a lot of these errors in the hs log. currently running 3.0.7364.22993, but was getting these errors with a previous version as well.
    Periodically the plugin just seems to stop, and no temperature updates are recorded. I have to restart the plugin, and power cycle my 1-wire network to get things going again
    Mark
    HS3 Pro 4.2.17.0
    How much times passes between a plug-in restart and the errors appearing in the logs?
      I restarted the plugin on 7/1 8:15am EST. I haven't seen an errors as of today (7/3).
      Its not easy getting a full picture of when stuff happens in the plugin as you have different error types. I'm filtering the HS log on Info entries and then flltering on Error.
      Feature request: use ULTRA1WIRE3 as the hs.writelog type, and then put your Info, Warning, Error keywords in the message itself. that way we can filter the hs log by ULTRA1WIRE3 and see everything you log on one screen.
      Mark
      HS3 Pro 4.2.17.0
        Crashed again
        Mark
        HS3 Pro 4.2.17.0
