Ultra1Wire2 HSPI for HomeSeer
Ultra1Wire2 is the next generation HomeSeer plug-in that makes tracking temperature and humidity in your home easy. By using the Embedded Data Systems Intelligent 1-Wire Interface Adapters and/or the Midon Design TEMP08 Serial One Wire Interface, this plug-in automatically creates and maintains a HomeSeer device for each 1-Wire environmental sensor detected. In addition, the temperature and humidity values for each environmental sensor are inserted into an underlying database for easy graphing/charting purposes.
This plug-in is *not* compatible with Ultra1Wire and is not an upgrade. Ultra1Wire2 is a 100% complete re-write. In addition, the underlying database and HomeSeer devices are not compatible. If you decided to upgrade to Ultra1Wire2, you'll need to print out the RomID's from each 1-wire device so you can re-define the room and location for the new HomeSeer devices.
Ultra1Wire2 Features:
Ultra1Wire2 Features Planned:
1-Wire Interfaces Supported:
1-Wire Temperature Sensors Supported:
- Free 30 Day Trial
- Written in VB.Net 2008; 100% managed code.
- Tested on Microsoft XP, Vista, Windows 7 and Windows 8.
- Available through the HomeSeer store
- Automatically discovers and builds HomeSeer devices for each DS18S20 and DS18B20 temperature sensors.
- Automatically discovers and builds HomeSeer devices for Humidity sensors.
- Logs all temperature readings to a OLEDB aware database. Default database uses SQLite (database included).
- Ability to open and close database connections while plug-in is running.
- Debugging output to troubleshoot database connection issues.
- Ability to specify custom database connection strings.
- Ability to purge database records after a specified number of months.
- Ability to trigger HomeSeer2 events based on the device temperature.
- Charts available via FusionCharts (flash based).
- Automatically discovers and builds HomeSeer devices for other sensors supported by the TEMP08.
- Support for 1-wire counters.
- HA7Net 1-Wire Interface ($155.95) See http://www.embeddeddatasystems.com/H...pter_p_22.html
- OW-SERVER - 1-Wire to Ethernet Server ($99.95) See http://www.embeddeddatasystems.com/O...ver_p_152.html
- HA7E 1-Wire Interface ($39.95) See http://www.embeddeddatasystems.com/H...pter_p_21.html
- Temp08 Unit by Midon Design ($75.00) See http://www.midondesign.com/TEMP08/TEMP08.html
- DS18S20 temperature sensors (~ $6 each)
- DS18B20 temperature sensors (~ $6 each)
- DS2438 based humidity/temperature sensors (~ $50 each)
- DS2406 baesed 1-wire switches (currently detects the switches and reports on the value)
- DS2423 based counters.
