I can add the webcontrol as a supported 1-wire interface. It should be very easy to add support for the temperature and humidity sensors as the plug-in already supports other ethernet connected devices.
How about web page options to strip the graphic and the degree symbols so it is simply a variable. I know a lot of people use the web gui for day to day use. I am a mainlobby user and all I want is the variable. Also I have events and such that trigger on device value change. I currently have scripts to strip the variable down to the bare essentials
Over The Hill
What Hill?
Where?
When?
I Don't Remember Any Hill
Virtualized Server 2k3 Ent X86 Guest on VMWare ESXi 4.1 with 3 SunRay thin clients as access points - HSPro 2.4.0.48 - ZTroller - ACRF2 (3 WGL 800's) - iAutomate RFID - Ledam - MLHSPlugin - Ultra1wire - RainRelay8 - TI103 - Ultramon - WAF-AB8SS - jvESS (11 zones) - Bitwise Controls BC4 - with 745 Total Devices - 550 Events - 104 scripts - 78 ZWave devices - 42 X10 devices - 76 DS10a's 3 RFXSenors and 32 Motion Sensors
Hello Jackpod. The HomeSeer device has both the device value and device string. The device string contains an image and degree symbol. The device value just stores the temperature, humidity, etc. Can mainlobby use the device value instead of the device string?
Hi Ultra, Yes, mainlobby can use the value attribute (but I want the degree symbol). Actually what I do now with a script, is strip the graphic, and strip the "F" from the end, send that info to Mainlobby via a set of HS virtuals and then strip the degree symbol and apply it to another set of HS Virtuals so I can trigger events on device value. Its a little kludgey but it works. I trigger the script once a minute to populate the 2 sets of HS virtuals
Over The Hill
What Hill?
Where?
When?
Actually I need to retract from my post above. Since the weather is finally starting to warm up and some of my defined thresholds are being met. I have found that my script is not working as I had thought. What I do is trigger ceiling fans when thresholds have been reached and well the fans are not coming on Being at 7,000 elevation I don't have air conditioning as we only get a couple weeks a year with temps above 85
Over The Hill
What Hill?
Where?
When?
Is Webcontrol Support still on the list? Any ETA? Thanks
I just ordered 2 temperature probes from eBay so I can monitor my audio/video cabinet with the Webcontrol. I'll be adding support for the temperature/humidity sensors soon.
