Ultra1Wire2 HSPI - Feature Requests
This is a sticky topic.
Originally posted by aldo View PostUntrajones,
This is no typical of you to no respond, perhaps you are not reading this post, if I don't get a response, I will open another post outside this one.
Aldo
Sent from my SM-G935V using Tapatalk
I am sorry I missed your original question. The temperature readings are inserted without modification. The HomeSeer device is configured to display resolution to 1 decimal point (which is shown in your data). You should be able to display it properly assuming you are referencing the device string instead of the device value.
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
1. i would like a trigger that will fire if the plugin loses connection with the interface.
2. an option to write log entries to the hs log in addition to the plugin .log file.
3. Move the plugin .log files in the Homeseer 3\Logs folder instead of root folder
4. Add the config link to the plugin name (Ultra1Wire3) on the Manage plugin page
5. ability to un-group all the temperature devices from the parent device
thanks for the consideration UltrajonesMark
HS3 Pro 3.0.0.534
