Not having much look with this plugin.
Disabled the plugin on the interfaces page but the plugin keeps running until homeseer is shutdown.
PHP Code:
07/09/2012 18:19:52 ~!~Plug-In~!~Shutting down generic Plug-In: Ultra1Wire2
07/09/2012 18:19:52 ~!~Ultra1Wire2 Info~!~Ultra1Wire2 - shutting down I/O ...
07/09/2012 18:19:52 ~!~Ultra1Wire2 Info~!~Database connection closed successfuly.
07/09/2012 18:20:16 ~!~Ultra1Wire2 Error~!~Watchdog Timer indicates the database connection is not active. Attempting to reconnect ...
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Ultra1Wire2 - initializing I/O ...
07/09/2012 18:20:16 ~!~Ultra1Wire2 Warning~!~Watchdog Timer indicates TCP connection to TEMP08 device [COM3] was lost.. Attempting to reconnect ...
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~TEMP08 initialized on COM3
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Setting TEMP08 Clock ...
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Enabling TEMP08 Serial Number ID display ...
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Setting TEMP08 temperature format ...
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Disabling TEMP08 update interval ...
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Getting TEMP08 version ...
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Watchdog Timer reconnect attempt succeeded.
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Adding to ignore list.
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~HA7E 1-wire interface is not enabled.
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~HA7Net 1-wire interface is not enabled.
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~OWServer 1-wire interface is not enabled.
07/09/2012 18:20:16 ~!~Ultra1Wire2 Info~!~Database initialization complete. Ready to accept HomeSeer events into database.
07/09/2012 18:21:31 ~!~Ultra1Wire2 Error~!~An unexpected error occured in the ProcessTEMP08CommandQueue() function/subroutine: [System.InvalidOperationException: Queue empty. at System.Collections.Queue.Dequeue() at HSPI_ULTRA1WIRE2.HS_TEMP08.ProcessTEMP08CommandQueue()]
07/09/2012 18:26:46 ~!~Ultra1Wire2 Warning~!~HomeSeer device ()2 did not report a value.
07/09/2012 18:28:01 ~!~Ultra1Wire2 Warning~!~HomeSeer device ()2 did not report a value.
07/09/2012 18:31:46 ~!~Ultra1Wire2 Warning~!~HomeSeer device ()2 did not report a value.
