I tested the following 1-Wire sensors and I confirm they are compatible with Ultra1Wire2 HSPI when used with the EDS HA7Net and EDS OWServer:
I just added support for the MS-TL - Temperature and Light Level Sensor so it properly reports a light level between 0 and 100.
Note: The Light sensor does not work with the TEMP08. In full light, the TEMP08 displays a voltage output as follows:
Humidity #01[9A000001409D0526]=04.77V 04.77V 00mV ???
Ultrajones
- MS-T - Temperature Sensor
- MS-TH - Temperature and Humidity Sensor
- MS-TL - Temperature and Light Level Sensor
Ultrajones
