SQL Server
  • SQL Server
    Hi Guys
    Anyone using SQL server? if so, where does it write the temperature from the sensors. It seems to ignore initial catalog in connection string and I don't see any new tables (just my ones from UltraLog)
    Regards
    Mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    I made some progress using SQL profiler and guessed at the schema. It's now writing data, but when i try to produce a chart I get this
    An unexpected error occured in the GetSensorChart() function/subroutine: [System.IndexOutOfRangeException: Cannot find table 0. at System.Data.DataTableCollection.get_Item(Int32 index) at HSPI_ULTRA1WIRE2.HSPI.GetSensorChart(Hashtable& PluginDevices, Hashtable& DeviceColors, String ChartType, ArrayList TempSensorList, DateTime dEndDateTime, String Interval)]
    This is failing because it's trying to use a column alias in a group by clause.
    PHP Code:
    SELECT
        120
    *(ts/120) as ts_epoch
    code as deviceCode
    AVG(value) as sensorValue
    FROM
        tblTemperature
    as
    WHERE
        ts
    >= 1388543481
    AND ts <= 1388545281
    AND code IN ('/1'
    GROUP BY
        ts_epoch
    , -- should be 120*(ts/120),
    code
    ORDER BY
        ts_epoch ASC
    USB UIRT
    2GIG Thermostat
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Global Cache IP2IR
    Foscam FI8918W
      Bump
      USB UIRT
      2GIG Thermostat
      BLUPS
      UltraLog (SQL2008)
      Jon00 Plugins
      Global Cache IP2IR
      Foscam FI8918W
        I'll look into this. I am not sure if you have noticed, but I am only using SQLite for my HS3 plug-ins. I have abandoned support for other database types.
        Ultrajones
          Ultrajones
          that's a real shame. Nobody really wants to run 2 SQL databases and he SQL is pretty straightforward
          USB UIRT
          2GIG Thermostat
          BLUPS
          UltraLog (SQL2008)
          Jon00 Plugins
          Global Cache IP2IR
          Foscam FI8918W
            Originally posted by mark_anderson_us View Post
            SQLite is a "self-contained, serverless, zero-configuration, transactional SQL database engine." There isn't anything you need to run or worry about
              True, but I use SQL reporting services and SSMS. Not sure if I can connect to an SQLLite DB with those. I noticed that you're now using monthly DB's for one of your plug-ins, which means my queries are much more complex to extract multi-month stats. If you don't want to rewrite the query every month, this will probably require a union query using dynamic sql which is poor from performance and security
              USB UIRT
              2GIG Thermostat
              BLUPS
              UltraLog (SQL2008)
              Jon00 Plugins
              Global Cache IP2IR
              Foscam FI8918W
