Ultra1Wire3 HSPI For HomeSeer3
This is a sticky topic.
    Description
    Ultra1Wire3 is the next generation HomeSeer plug-in that makes tracking temperature and humidity in your home easy. By using the Embedded Data Systems Intelligent 1-Wire Interface Adapters and/or the Midon Design TEMP08 Serial One Wire Interface, this plug-in automatically creates and maintains a HomeSeer device for each 1-Wire environmental sensor detected. In addition, the temperature, humidity, barometric pressure and counter values for each 1-Wire sensor are inserted into an underlying database for graphing purposes.
    When connecting any of the supported 1-Wire Host Adapters to HomeSeer using the Ultra1Wire3 plug-in, you can automate devices controlled by HomeSeer based on the sensor readings from 1-Wire Host Adapters.
    How It Works
    • The plug-in connects to any of the supported 1-Wire Host Adapters and obtains a list of supported 1-wire devices.
    • When using the HA7Net or OW-Server 1-Wire host adapters, the plug-in checks the value of each connected digital environmental sensor then updates the HomeSeer device and inserts temperature, humidity, barometric pressure and counter readings into the database.
    • When using the HA7E 1-Wire host adapter, the plug-in checks the value of each connected digital environmental temperature sensor then updates the HomeSeer device and inserts temperature readings into the database.
    • When using the TEMP08 host adapter, the plug-in reads the output of all connected devices then updates the HomeSeer device and inserts temperature, humidity, barometric pressure and counter readings into the database.
    • 30 day free trial.
    • Automatically discovers and builds HomeSeer devices for each supported 1-Wire environmental sensor.
    • Logs all temperature, humidity, counter and barometric pressure readings to an underlying database.
    • Temperature, humidity, counter and barometric pressure charts are created using AMCharts http://www.amcharts.com/.
    • Ability to trigger HomeSeer3 events based on 1-Wire device sensor readings.
    • Error Try/Catch logic to ensure plug-in doesn't fail with an unhandled exception.
    • Multiple threading allows 1-Wire readings to take place without disrupting the performance of HomeSeer.
    Example Usage
    • Use Ultra1Wire3 to generate an e-mail notification whenever an environmental sensor exceeds a set threshold.
    • Use Ultra1Wire3 to monitor installed temperature sensor in your child’s room and receive e-mail notification using a HomeSeer event when the temperature exceeds a set threshold.
    • Use Ultra1Wire3 to monitor installed humidity sensor in your basement and receive e-mail notification using a HomeSeer event when the humidity exceeds a set threshold.
    • Use Ultra1Wire3 with installed indoor and outdoor temperature and humidity sensors to receive notifications using a HomeSeer event when it’s more efficient to open your windows instead of turning on your air conditioner.
    • Use Ultra1Wire3 along with installed temperature sensor to monitor the ambient temperature of an enclosed media cabinet.
    Change Log
    Version 3.0.5321.26106 - Released July 29, 2014
    • Change resolution of counter device.
    Version 3.0.5324.31161 - Released July 30, 2014
    • Update amCharts to version 3.10.0
    Version 3.0.5443.15312 - Released Nov 26, 2014
    • The plug-in web pages now use HomeSeer jQuery controls instead of ASXP.
    • Updated the charting web page to support queries of up to 1 year.
    • The plug-in now runs under Linux.
    • Added support for the Embedded Data Systems MeshNet™ Wireless Sensor System (http://www.embeddeddatasystems.com/MeshNet_c_65.html).
    Version 3.0.5443.15312 - Released Dec 20, 2014
    • Minor bug fixes.
    Version 3.0.5538.23621 - Released Mar 01, 2015
    • Fixed routine that disabled orphaned sensors.
    • Other minor bug fixes.
    Version 3.0.5566.14727 - Released Mar 29, 2015
    • Fixed delay between check option.
    Version 3.0.5579.15955 - Released Apr 11, 2015
    • Fixed chart legend spacing issues.
    • Modified plug-in so 1-wire device properties are no longer reset.
    Version 3.0.6159.34883 - Released Nov 11, 2016
    • Added support the Embedded Data Systems OW-RTD4W 1-Wire Interface for 4-Wire RTD that expands the temperature range (-200C to 850C) measurable through 1-Wire.
    Version 3.0.6280.35072 - Released Mar 12, 2017
    • Fixed issue with TEMP05 humidity sensor readings.
    Version 3.0.6405.17148 - Released July 15, 2017
    • Updated plug-in to ensure resources are properly released if a connection cannot be made to the remote endpoint (e.g. OWServer).
    Version 3.0.6510.21140 - Released Oct 28, 2017
