Error with newest Vers
  • Error with newest Vers
    After installing the latest vers (.15312), I now get these in the HS log:
    Dec-06 11:16:13 AM Error Input string was not in a correct format.
    It's not listed as being from 1Wire, but when I stop the plugin, the error stops.
    All of the devices the Temp08 is connected to seem to be responding and displaying valid temps, so not sure what it is.
    Z
    I'm logging Error Input string was not in a correct format about every 2 minutes
    I'm logging this error from Ultra1Wire3 about every 2 minutes.
    Dec-13 8:18:34 AM Error Input string was not in a correct format.
    Dec-13 8:17:01 AM Error Input string was not in a correct format.
    Dec-13 8:15:29 AM Error Input string was not in a correct format.
    Dec-13 8:13:56 AM Error Input string was not in a correct format.
    Dec-13 8:12:24 AM Error Input string was not in a correct format.
    Dec-13 8:10:51 AM Error Input string was not in a correct format.
    Do you have any idea how to fix that? I just updated to the .15312 HSPI but was getting the same thing before doing that.
      Can you enable debug, then send the output file created in the HomeSeer root directory to ultrajones@hotmail.com? You should only need to run debug for about 2 minutes.
      Ultrajones
        Can you download Ultra1Wire3 HSPI version 3.0.5461.16453, then let me know if those errors stop?
        Ultrajones
          No more errors after .16453
          That new update has fixed the errors. Everything else is working fine now.
          Unconfigured PHP Module
