Monitor Temperatures Between -200C to 850C
This is a sticky topic.
    I just released an update to my plug-in to support the OW-RTD4W 1-Wire Interface for 4-Wire RTD that expands the temperature range (-200C to 850C) measurable through 1-Wire. If you have a need to measure temperature between (-200C to 850C), then you'll need to purchase:
    Parts Available from Embedded Data Systems:
    1 - OW-SERVER: 1-Wire to Ethernet Server, Revision 2
    1 - OW-RTD4W - 1-Wire Interface for 4-Wire RTD
    1 - EDS0071 RTD Interface, 4 wire Temperature Probe
    Plugin Available Via HomeSeer:
    1- The Ultra1Wire3 HSPI available via HomeSeer store.
    Ultrajones
    You know the weather sucks if you are getting - 200 degrees...
    Sent from my SM-T815Y using Tapatalk
    HS3 PRO, Win10, WeatherXML, HSTouch, Pushover, UltraGCIR, Heaps of Jon00 Plugins, Just sold and about to move so very slim system.
    Facebook | Twitter | Flickr | Google+ | Website | YouTube
      UltraJones,
      Outstanding. I've been trying to get my oven temp into HS3 using the Arduino Plugin. The temp readings are non-linear and my coding skills are limited. I can get the input into HS3, but I can't get it aligned with the actual temperature reading.
      The OW-RTD4W will make this much easier. I do have one questions. It appears the EDS0071 is a discontinued interface. Just to be clear please confirm I only need one or the other, not both.
      Forrest
        Oh oven and freezer temps that makes sense... thought for a second ha has been implemented on mars. Would've helped out Matt Damon for sure.
          Ultra1Wire3 works with EDS OW-RTD4W & Omega PT100 Probe
          Ultra1Wire3 plugin is working great with the OW-RTD4W. I'm using it to report my oven with an Omega PT100 4-Wire RTD part number RTD-3-1PT100K2515-36-G. https://www.omega.com/temperature/pd...PT100K2515.pdf
          Forrest
            Do you know if this sensor works with Temp08?
            Sent from my SM-G935V using Tapatalk
