Help - Airport wont show up as client
  • Help - Airport wont show up as client
    Ok, what am I doing wrong...
    I have an Airport Express running, it is playing music so I know it, and the speakers work.
    Airplay Speakers configuration Show the Device...
    D0034B5D28B2 Ninovan1 AirPortExpress
    But when I go to "Speak Something" and I look at "Edit Speaker Client List" it is not there.
    I have rebooted...restarted, etc...
    Gotten some WEIRD error messages...
    Mar-06 6:49:53 PM AirplaySpeak INFO Connection to Ninovan1 (192.168.86.60:5000) failed: Request failed, error RTSP/1.0 453 Not Enough Bandwidth
    Mar-06 6:49:53 PM TTS Speak: ():This is a test
    Mar-06 6:49:53 PM AirplaySpeak INFO (Ninovan1): This is a test
    Mar-06 6:49:53 PM Event Event Trigger "Ninovan Events Airplay test"
    OK...I got rid of that error by turning off the Music that was playing WIRELESSLY to the AirPortExpress.
    The AirportExpress is WIRELESS, as is most everything in this house...
    But still nothing to the Airport speakers, not even a click or pop
    here is a DEBUG Log for the last try
    Mar-06 7:07:21 PM AirplaySpeak DEBUG RECORD rtsp://192.168.86.22/1431291506 RTSP/1.0 CSeq: 3 Session: 1 Range: npt=0- RTP-Info: seq=4655;rtptime=38110 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: A1F2ECD85BEBC699
    Mar-06 7:07:21 PM AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog
    Mar-06 7:07:21 PM AirplaySpeak DEBUG Server, AirTunes/105.1
    Mar-06 7:07:21 PM AirplaySpeak DEBUG Transport, RTP/AVP/UDP;unicast;mode=record;server_port=6000;control_port=6001;t iming_port=6002
    Mar-06 7:07:21 PM AirplaySpeak DEBUG CSeq, 2
    Mar-06 7:07:21 PM AirplaySpeak DEBUG Session, 1
    Mar-06 7:07:20 PM AirplaySpeak DEBUG SETUP rtsp://192.168.86.22/1431291506 RTSP/1.0 CSeq: 2 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=49669;timing_port=49668 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: A1F2ECD85BEBC699
    Mar-06 7:07:20 PM AirplaySpeak DEBUG Server, AirTunes/105.1
    Mar-06 7:07:20 PM AirplaySpeak DEBUG CSeq, 1
    Mar-06 7:07:20 PM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.86.22/1431291506 RTSP/1.0 CSeq: 1 Content-Type: application/sdp Content-Length: 184 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: A1F2ECD85BEBC699 v=0 o=iTunes 1431291506 0 IN IP4 192.168.86.22 s=iTunes c=IN IP4 192.168.86.60 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
    Mar-06 7:07:20 PM AirplaySpeak DEBUG 35 Speaker.Reset() gets the lock
    Mar-06 7:07:20 PM TTS Speak: ():This is a test
    Mar-06 7:07:20 PM AirplaySpeak INFO (Ninovan1): This is a test
    Mar-06 7:07:20 PM Event Event Trigger "Ninovan Events Airplay test"
    Mar-06 7:07:20 PM Event Event Ninovan Events Airplay test triggered by the event page 'Run' button.
    Nothing about Ninovan1, the only Airplay speak client
    Help Please !
    A minute or so AFTER I pulled the above, the following showed up in the log...
    Mar-06 7:07:53 PM AirplaySpeak DEBUG 35 Speaker.AfterSend()
    Mar-06 7:07:53 PM AirplaySpeak DEBUG 35 Speaker.SendSample() gets lock
    Mar-06 7:07:53 PM AirplaySpeak DEBUG 35 Speaker.BeforeSend()
    Mar-06 7:07:53 PM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
    Mar-06 7:07:53 PM AirplaySpeak INFO Connection to Ninovan1 (192.168.86.60:5000) failed: Request failed, error RTSP/1.0 500 Internal Server Error
    Internal Server Error - Uhm -- is that on the HS3 side or the AirportExpress side? And how do I fix that?
    Is that part of why it isn't showing up?
    (PS... I checked, bonjour is running, what else can I check?)
      the airplay speakers will never show in the "Edit Speaker Client List" because there is no way to do that from the HS API. You have to either add the speaker manually to the list, or do not specify any target so that the TTS will be send to all speakers.
      To test the plugin with your Airport Express, make sure no other source (iTunes) is sending audio to the speaker, and use something longer than "This is a test", airplay speakers have trouble with very short audio.
      You can also play with the "Delay Before" / "Delay After" settings to improve things
        Ah... that helps...
        I will add some delay at the beginning and see what happens...
        What about the "internal Server Error".... what should I be looking for for that ?
