AirPlay Error
  • AirPlay Error
    I have never gotten Airplay to work right, and got sidelined with other projects...
    I forgot that my wife installed an Apple TV...
    So the Update this morning reminded me to look at AirSpeak again...
    Mar-23 8:16:07 AM AirplaySpeak DEBUG 128 Speaker.AfterSend()
    Mar-23 8:16:07 AM AirplaySpeak DEBUG 128 Speaker.SendSample() gets lock
    Mar-23 8:16:07 AM AirplaySpeak DEBUG 128 Speaker.BeforeSend()
    Mar-23 8:16:07 AM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
    Mar-23 8:16:07 AM AirplaySpeak INFO Connection to Sewing room tv box (192.168.86.66:7000) failed: Request failed, error RTSP/1.0 500 Internal Server Error
    I know I have to put in delays before it starts speaking, but what about this error? I have no idea where to start?
    Ok, I tried with my TEST Apple box.
    Plays NICE music. If it is playing via Wifi, I will get a "Not enough Bandwidth" message when I try to TTS to it while it is playing.
    So I turned off the nice music... and sent it a LONG test message.
    All of the PC's played the message, none of the apples did. here is the debug log.
    Mar-23 5:56:36 PM AirplaySpeak DEBUG RECORD rtsp://192.168.86.22/3760960729 RTSP/1.0 CSeq: 3 Session: 1 Range: npt=0- RTP-Info: seq=4472;rtptime=38634 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 5571633618B1D144
    Mar-23 5:56:36 PM AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog
    Mar-23 5:56:36 PM AirplaySpeak DEBUG Server, AirTunes/105.1
    Mar-23 5:56:36 PM AirplaySpeak DEBUG Transport, RTP/AVP/UDP;unicast;mode=record;server_port=6000;control_port=6001;t iming_port=6002
    Mar-23 5:56:36 PM AirplaySpeak DEBUG CSeq, 2
    Mar-23 5:56:36 PM AirplaySpeak DEBUG Session, 1
    Mar-23 5:56:36 PM AirplaySpeak DEBUG SETUP rtsp://192.168.86.22/3760960729 RTSP/1.0 CSeq: 2 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=55017;timing_port=55016 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 5571633618B1D144
    Mar-23 5:56:36 PM AirplaySpeak DEBUG CSeq, 1
    Mar-23 5:56:36 PM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.86.22/3760960729 RTSP/1.0 CSeq: 1 Content-Type: application/sdp Content-Length: 184 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 5571633618B1D144 v=0 o=iTunes 3760960729 0 IN IP4 192.168.86.22 s=iTunes c=IN IP4 192.168.86.69 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
    Mar-23 5:56:36 PM AirplaySpeak DEBUG 122 Speaker.Reset() gets the lock
    Mar-23 5:56:36 PM AirplaySpeak DEBUG 262 Speaker.AfterSend()
    Mar-23 5:56:36 PM AirplaySpeak DEBUG 262 Speaker.SendSample() gets lock
    Mar-23 5:56:36 PM AirplaySpeak DEBUG 262 Speaker.BeforeSend()
    Mar-23 5:56:36 PM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
    Mar-23 5:56:36 PM AirplaySpeak INFO Connection to Sewing room tv box (192.168.86.66:7000) failed: Request failed, error RTSP/1.0 500 Internal Server Error
    Mar-23 5:56:19 PM TTS Speak: ():this is a test of the emergency broadcast system, in the event of a real emergency you would have been told where to tune in your local area for news and information. This concludes this test of the emergency broadcast system.
    Mar-23 5:56:19 PM AirplaySpeak INFO (Ninovan1,Sewing room tv box): this is a test of the emergency broadcast system, in the event of a real emergency you would have been told where to tune in your local area for news and information. This concludes this test of the emergency broadcast system.
    Mar-23 5:56:19 PM System Control Panel Immediate Script: &hs.speak "this is a test of the emergency broadcast system, in the event of a real emergency you would have been told where to tune in your local area for news and information. This concludes this test of the emergency broadcast system."
    Not a SOUND out of my test Apple box.
      sorry for the delay
      I guess you run HS3 on Windows? If so it's probably the windows firewall that causes the problem. Disable the windows firewall temporarily to test, if it works then you need to add a rule to let the HSPI_AIRPLAY_SPEAK.exe communicate on your local network.
        Hum...
        I will try that, but normally if a program wants to use the network I get a POP-UP from the firewall asking for permission...
        (Ran into that withHSTouch)
        But I will try it and see if I am missing it because it is in the closet downstairs, maybe it goes away before I get downstairs...
          there is very good chances this is the problem, I tried to send TTS to my Apple TV with the windows firewall turned on, and I got the "500 Internal Server Error"
            I put the API into the Firewalls 'OK' list....
            Error changed a bit....
            Apr-02 11:24:19 AM AirplaySpeak INFO Connection to Sewing room tv box (192.168.86.66:7000) failed: Request failed, error RTSP/1.0 403 Forbidden
            Note: EVERYTHING in this house is wireless... and I have seen issues where something was playing to the device and got back a "not enough bandwidth" message...
            The PLAN is to get AirSpeak working and put in some dumb, but dedicated, airplay speakers whose ONLY job is to play announcements. I may bridge (y-cord) the device into the existing system to see if that works, once I get it working reliably...
              it looks like a recent update of tvos prevent from setting the Airplay security to None.
              I need to look at how I can make the plug-in work with a passcode/password
              https://discussions.apple.com/thread...art=0&tstart=0
                I confirmed the problem comes from tvOS 10.2, I downgraded to 10.1.1 using this guide, and the AirplaySpeak plug-in works again (by setting security=none in the Airplay settings of the AppleTV).
                I will try to come up with a solution for 10.2, but it may take some time as a new device verification mechanism is now required. So at this point it's better to not upgrade to tvOS 10.2 (or downgrade to 10.1.1)
                  Still Getting errors
                  This is an AirPort Express, ver 7.6.8
                  It plays music from my iPad wonderfully
                  If it is playing music I get "Not enough Bandwidth" which is Understandable
                  But if it is quiet, nothing playing and I try TTS to it... I get...
                  Apr-06 3:42:58 PM AirplaySpeak DEBUG 34 Speaker.AfterSend()
                  Apr-06 3:42:58 PM AirplaySpeak DEBUG 34 Speaker.SendSample() gets lock
                  Apr-06 3:42:58 PM AirplaySpeak DEBUG 34 Speaker.BeforeSend()
                  Apr-06 3:42:58 PM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
                  Apr-06 3:42:58 PM AirplaySpeak INFO Connection to Ninovan1 (192.168.86.72:5000) failed: Request failed, error RTSP/1.0 500 Internal Server Error
                  Apr-06 3:42:43 PM Z-Wave Device: Node 7 Living Room Temperature Set to 69.44 (F)
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG RECORD rtsp://192.168.86.22/1877256831 RTSP/1.0 CSeq: 4 Session: 1 Range: npt=0- RTP-Info: seq=3047;rtptime=35295 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: E9CD64123241B1C7
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG Server, AirTunes/105.1
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG Transport, RTP/AVP/UDP;unicast;mode=record;server_port=6000;control_port=6001;t iming_port=6002
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG CSeq, 3
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG Session, 1
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG SETUP rtsp://192.168.86.22/1877256831 RTSP/1.0 CSeq: 3 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=51923;timing_port=51922 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: E9CD64123241B1C7
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG CSeq, 2
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.86.22/1877256831 RTSP/1.0 CSeq: 2 Content-Type: application/sdp Content-Length: 184 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: E9CD64123241B1C7 v=0 o=iTunes 1877256831 0 IN IP4 192.168.86.22 s=iTunes c=IN IP4 192.168.86.72 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG CSeq, 1
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG Public, ANNOUNCE, SETUP, RECORD, PAUSE, FLUSH, TEARDOWN, OPTIONS, GET_PARAMETER, SET_PARAMETER, POST, GET
                  Apr-06 3:42:26 PM AirplaySpeak DEBUG OPTIONS * RTSP/1.0 CSeq: 1 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: E9CD64123241B1C7
                  Apr-06 3:42:25 PM AirplaySpeak DEBUG 34 Speaker.Reset() gets the lock
                  Apr-06 3:42:25 PM AirplaySpeak DEBUG 14 Speaker.AfterSend()
                  Apr-06 3:42:25 PM AirplaySpeak DEBUG 14 Speaker.SendSample() gets lock
                  Apr-06 3:42:25 PM AirplaySpeak DEBUG 14 Speaker.BeforeSend()
                  Apr-06 3:42:25 PM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
                  Apr-06 3:42:25 PM AirplaySpeak INFO Connection to Ninovan1 (192.168.86.72:5000) failed: Request failed, error RTSP/1.0 500 Internal Server Error
                  Apr-06 3:42:09 PM AirplaySpeak INFO (Ninovan1): This is a text
                  Apr-06 3:42:08 PM Event Event Trigger "Ninovan Events Airplay test"
                  Apr-06 3:42:08 PM Event Event Ninovan Events Airplay test triggered by the event page 'Run' button.
                  The AirPlay Speak API is in the Firewalls "white list"
                  Again, I am ALL Wireless if that makes a difference....
                    Please turn off completely your firewall before testing, this is the cause of most of "500 Internal Server" errors
                    wireless should not make any difference
                    "Not enough Bandwidth" means another program (i.e. iTunes) is connected to the speaker, so close this other program.
                    Then test with a longer message than "This is a test".
                      Got it to work !
                      OK... it is NOT a firewall issue as I got it to work with another iReciever, a non-apple device that is DLNA device.
                      (https://www.amazon.com/iReceiver-Wi-.../dp/B00I0Z427E)
                      The Debug log was TOTALLY different just by switching devices, and No error.
                      The following is from the AirMobi iReciever.
                      Apr-06 4:54:01 PM AirplaySpeak DEBUG TIMING EXCEPTIONA blocking operation was interrupted by a call to WSACancelBlockingCall
                      Apr-06 4:54:01 PM AirplaySpeak DEBUG TEARDOWN rtsp://192.168.86.22/0669243652 RTSP/1.0 CSeq: 6 Session: DEADBEEF User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 9D27877E0C30E416
                      Apr-06 4:54:01 PM AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog
                      Apr-06 4:54:01 PM AirplaySpeak DEBUG CSeq, 5
                      Apr-06 4:54:01 PM AirplaySpeak DEBUG FLUSH rtsp://192.168.86.22/0669243652 RTSP/1.0 CSeq: 5 Session: DEADBEEF RTP-Info: seq=3912;rtptime=762325 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 9D27877E0C30E416
                      Apr-06 4:54:01 PM AirplaySpeak DEBUG 32 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:54:01 PM Z-Wave Device: Node 5 Computer Area Multi Luminance Set to 21.77 (%)
                      Apr-06 4:54:01 PM AirplaySpeak DEBUG 34 Speaker.OnQueueEnd() gets the lock
                      Apr-06 4:54:00 PM Z-Wave Device: Node 5 Computer Area Multi Relative Humidity Set to 50.38 (%)
                      Apr-06 4:54:00 PM AirplaySpeak DEBUG 30 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:54:00 PM Z-Wave Device: Node 5 Computer Area Multi Temperature Set to 70.808 (F)
                      Apr-06 4:53:59 PM AirplaySpeak DEBUG 31 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:58 PM AirplaySpeak DEBUG 32 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:57 PM AirplaySpeak DEBUG 30 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:56 PM AirplaySpeak DEBUG 31 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:55 PM AirplaySpeak DEBUG 32 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:54 PM AirplaySpeak DEBUG 30 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:53 PM AirplaySpeak DEBUG 31 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:52 PM AirplaySpeak DEBUG 32 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:51 PM AirplaySpeak DEBUG 30 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:50 PM AirplaySpeak DEBUG 31 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:49 PM AirplaySpeak DEBUG 32 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:48 PM AirplaySpeak DEBUG 30 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:47 PM AirplaySpeak DEBUG 31 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:46 PM AirplaySpeak DEBUG 30 Speaker.OnCheckStatusTimerEvent() gets the lock
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG 38 Speaker.AfterSend()
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG 38 Speaker.SendSample() gets lock
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG 38 Speaker.BeforeSend()
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG CSeq, 4
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG SET_PARAMETER rtsp://192.168.86.22/0669243652 RTSP/1.0 CSeq: 4 Session: DEADBEEF Content-Type: text/parameters Content-Length: 19 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 9D27877E0C30E416 volume: -1.000000
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG CSeq, 3
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG RECORD rtsp://192.168.86.22/0669243652 RTSP/1.0 CSeq: 3 Session: DEADBEEF Range: npt=0- RTP-Info: seq=1932;rtptime=65365 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 9D27877E0C30E416
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG Transport, RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=57207;timing_port=57206;server_po rt=6015
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG CSeq, 2
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG Session, DEADBEEF
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG SETUP rtsp://192.168.86.22/0669243652 RTSP/1.0 CSeq: 2 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=57207;timing_port=57206 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 9D27877E0C30E416
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG CSeq, 1
                      Apr-06 4:53:45 PM AirplaySpeak DEBUG Apple-Response, SUwvC/v5NEXpcuS1W8wxwJSpKX1HtZWXUWyEGd8A2xQBoQK2GKWS2eS6zK2fO9fTbG wxQQuT3QO5LzLNugfrBb2SCH0pmOHL+1t3AnOnVpAwCNT9H+DMFlExV5PUBI aW/DY3KRDjIdERLeYOmF/kNJtFmaZwL6tanm2UFj9DDEsdM92PDvGZNeJOaQjdlJCflmsrhuN5tqcI4xY 80fuISOxCbTIu42uOxy1MxlXWAEeM0r3xz8U1o6p7Sr7JQasmkfb3tvuzhlf WbJIlWVjKOzDNbYFQethSQciwNxwJ540eir2OpuopL8g7jXrtbvJp6PBLfxO xvczfF4MMFz35rg
                      Apr-06 4:53:43 PM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.86.22/0669243652 RTSP/1.0 CSeq: 1 Content-Type: application/sdp Content-Length: 572 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 9D27877E0C30E416 Apple-Challenge: v2JordaIQ6xt0MV4latPrA v=0 o=iTunes 0669243652 0 IN IP4 192.168.86.22 s=iTunes c=IN IP4 192.168.86.74 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100 a=rsaaeskey:ItW6m6vE97I4DYb7NjzKe9oZGbFXvID71+c/znaaILJgqlzzwdRMAaYwHDln9hAojesqZ18kAWpg6TvZ6hQacI73J8d5a8X5 2PTMmFf8aOf17fY5yegWMoWwYvNGzOqzSXhmtHuAIIedTjZrm8rL3kcG6HZD K/x50yFR4njuHk9k+5gqv9cAAIMe8yiBL42PrcYCj0k+dm6T4VgozgUms0ODih Z5+Drbn1pOGr8TBaBMh1KYpIRJCCJ+4imL6mXxuh83PUWTo5LTfe3lUHd9y9 Gs99AyljCE3EsGkdPueJjXnx82xlvXH6VtQ+K0lCiwi77uIppc5G3e0y2kBG pIRw a=aesiv:6lyYGjz7wVaJDRIdvTfpMg
                      Apr-06 4:53:43 PM AirplaySpeak DEBUG 38 Speaker.Reset() gets the lock
                      Apr-06 4:53:43 PM AirplaySpeak INFO (Ninovan-1): This is a test of the emergency broadcasting system. In the event of a real emergency you would have been told where to tune in your area for local news and information. This concludes our test of the emergency broadcasting system.
                      Apr-06 4:53:43 PM Event Event Trigger "Ninovan Events Airplay test"
                      Apr-06 4:53:43 PM Event Event Ninovan Events Airplay test triggered by the event page 'Run' button.
                        I have both the AirPort Express and the iReciever on a bench, and I can switch between them. Both of them have been reset (several times) and are seen by Airplay.
                        The Following is the Log from the Air-Port Express. Exact same Event as above, just the iReciever was disabled and the Airport Express Enabled.
                        Something else is going on, some interaction is messing up the AirPort Express and not the generic DNLA device.
                        Apr-06 5:03:33 PM AirplaySpeak DEBUG 17 Speaker.AfterSend()
                        Apr-06 5:03:33 PM AirplaySpeak DEBUG 17 Speaker.SendSample() gets lock
                        Apr-06 5:03:33 PM AirplaySpeak DEBUG 17 Speaker.BeforeSend()
                        Apr-06 5:03:33 PM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
                        Apr-06 5:03:33 PM AirplaySpeak INFO Connection to Bob's AirPort Express (192.168.86.72:5000) failed: Request failed, error RTSP/1.0 500 Internal Server Error
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG RECORD rtsp://192.168.86.22/0350685367 RTSP/1.0 CSeq: 3 Session: 1 Range: npt=0- RTP-Info: seq=1052;rtptime=12468 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: F9E8935103A7BD38
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG Server, AirTunes/105.1
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG Transport, RTP/AVP/UDP;unicast;mode=record;server_port=6000;control_port=6001;t iming_port=6002
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG CSeq, 2
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG Session, 1
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG SETUP rtsp://192.168.86.22/0350685367 RTSP/1.0 CSeq: 2 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=55726;timing_port=55725 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: F9E8935103A7BD38
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG CSeq, 1
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.86.22/0350685367 RTSP/1.0 CSeq: 1 Content-Type: application/sdp Content-Length: 184 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: F9E8935103A7BD38 v=0 o=iTunes 0350685367 0 IN IP4 192.168.86.22 s=iTunes c=IN IP4 192.168.86.72 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
                        Apr-06 5:03:00 PM AirplaySpeak DEBUG 17 Speaker.Reset() gets the lock
                        Apr-06 5:03:00 PM AirplaySpeak INFO (Bob's AirPort Express): This is a test of the emergency broadcasting system. In the event of a real emergency you would have been told where to tune in your area for local news and information. This concludes our test of the emergency broadcasting system.
                        Apr-06 5:03:00 PM Event Event Trigger "Ninovan Events Airplay test"
                        Apr-06 5:03:00 PM Event Event Ninovan Events Airplay test triggered by the event page 'Run' button.
                          Sorry, one more comment since I had everything on a Bench.
                          I turned "forward to HS Speakers" back on....
                          The Local HS Speaker had FINISHED Playing the message before the AirPlay even began. Is "delay" in seconds, tenths or 10s of seconds?
                          Going to play a bit more before I have to turn AirPlay back off and return the HS3 system to normal operation running the house.
                            Hum...
                            "Wait for Speech to Finish" has a major effect, un-selected and airplay doesn't work at all.
                            Select it, and Airplay works, although it seems to play AFTER the HS Speakers are finished.
                              One More...
                              I was playing music to the iReciever... Expected "Not enough Bandwidth" but got something totally different.
                              Let me know what tests you want me to run. I have access to an AppleTv, an Airport Express and a generic DNLA reciever.
                              Apr-06 5:33:36 PM AirplaySpeak DEBUG 31 Speaker.AfterSend()
                              Apr-06 5:33:36 PM AirplaySpeak DEBUG 31 Speaker.SendSample() gets lock
                              Apr-06 5:33:36 PM AirplaySpeak DEBUG 31 Speaker.BeforeSend()
                              Apr-06 5:33:36 PM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.AnnounceSDP(String SDP) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
                              Apr-06 5:33:36 PM AirplaySpeak INFO Connection to Ninovan-1 (192.168.86.74:5293) failed: Request failed, read error
                              Apr-06 5:33:36 PM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.86.22/0700402877 RTSP/1.0 CSeq: 1 Content-Type: application/sdp Content-Length: 572 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 8F22ACA69588B35B Apple-Challenge: MIGi/dmxhdKqhkagq/T6Jw v=0 o=iTunes 0700402877 0 IN IP4 192.168.86.22 s=iTunes c=IN IP4 192.168.86.74 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100 a=rsaaeskey:rkIQk3FRifDVm86/sCTsO4Bql6reFe31YKGz9P14dfZXSuf6e1rvvxp0+DXMG5aXPkCJ/LXWH4nIjEy3DrPrchGLpw3B7jbUipFM80JMUq/7P0i3EubpRAsdalQF+OXXWffLz66wBEbwmBvszBI7XCmKgeVa6palXxHVNx+ TS+XgEMfBZ5qiHFhc1U07wsUkObCsCQ8DJMxq+TilIbNU16fmXFFWwrkaMeb JLqjYAYktIZiKjnRDeGaA/2s1T5CASxj/wTZbAd8u4zQ0FX7xIssH/OOKV5lGL5Bh5z5Y3hJOngGCo7jMBSEL6yK0C0QO2vy5zSwiK2f3iMrh0YIzP w a=aesiv:+QLAfWWWGIqrXRDL8a2VHg
                              Apr-06 5:33:36 PM AirplaySpeak DEBUG 31 Speaker.Reset() gets the lock
                              Apr-06 5:33:22 PM TTS Speak: ():This is a test of the emergency broadcasting system. In the event of a real emergency you would have been told where to tune in your local area for news and information. This concludes our test of the emergency broadcasting system.
                              Apr-06 5:33:22 PM AirplaySpeak INFO (Ninovan-1): This is a test of the emergency broadcasting system. In the event of a real emergency you would have been told where to tune in your local area for news and information. This concludes our test of the emergency broadcasting system.
                              Apr-06 5:33:21 PM Event Event Trigger "Ninovan Events Airplay test"
                              Apr-06 5:33:21 PM Event Event Ninovan Events Airplay test triggered by the event page 'Run' button.
