Need help
  • Need help
    Need help please. Airplay plugin was able to discover my apple home pods however I can't get figure out how to have them speak something. I tried creating an event and than using advanced event tab I created Kitchen for speaker in event. However nothing happens when I have event run.
    This is what I see in my log
    Feb-15 9:22:40 PM AirplaySpeak INFO Connection to Kitchen (192.168.0.43:7000) failed: SETUP: no timing_port in response
    Feb-15 9:22:40 PM AirplaySpeak INFO (Kitchen): Test Test Test
    Feb-15 9:22:40 PM Event Event Trigger "Homeseer Home Events airplay test"
    you are the first to test this plugin with HomePod
    Could you set the log level to debug and post what you get when the plugin discovers the device (restart the plugin) as well as when you try to Speak something from HS.
      debug log when restarting plugin
      here is debug from restarting plugin
      Feb-16 7:22:40 PM AirplaySpeak DEBUG vv = '2'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG ov = '11.2.5'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG vs = '356.19'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG vn = '65537'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG tp = 'UDP'
      Feb-16 7:22:40 PM Plug-In Finished initializing plug-in AirplaySpeak
      Feb-16 7:22:40 PM AirplaySpeak DEBUG pk = '46630b81196aba9d8f9dedeb543a15a452eace2dfb381385df67e3f7bf0 ce340'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG am = 'AudioAccessory1,1'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG md = '0,1,2'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG sf = '0x404'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG ft = '0x4A7FCA00,0x56BD0'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG et = '0,3,5'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG da = 'true'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG cn = '0,1,2,3'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG TXT Records =
      Feb-16 7:22:40 PM AirplaySpeak INFO Resolved Service: D4A33D6B4AA4 - Master Bath - 192.168.0.45 - 7000
      Feb-16 7:22:40 PM AirplaySpeak INFO Found Service: D4A33D6B4AA4@Master Bath
      Feb-16 7:22:40 PM AirplaySpeak DEBUG pk = 'e77a59f4c4a52a7831e7d52326dd501acbd2647a1b0d701477fb40320a1 05b87'
      Feb-16 7:22:40 PM AirplaySpeak INFO Resolved Service: D4909CD03BD3 - Master Bedroom - 192.168.0.44 - 7000
      Feb-16 7:22:40 PM AirplaySpeak INFO Found Service: D4909CD03BD3@Master Bedroom
      Feb-16 7:22:40 PM AirplaySpeak DEBUG sm = 'false'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG pw = 'false'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG ft = '0xCFA3F7'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG txtvers = '1'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG sv = 'false'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG ek = '1'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG am = 'Airtight,1'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG sf = '0x4'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG vn = '3'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG ch = '2'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG et = '0,1'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG cn = '0,1'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG sr = '44100'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG ss = '16'
      Feb-16 7:22:40 PM AirplaySpeak INFO Resolved Service: 10AF60F518D2 - Fire TV - 192.168.0.3 - 49152
      Feb-16 7:22:40 PM AirplaySpeak INFO Found Service: 10AF60F518D2@Fire TV
      Feb-16 7:22:40 PM AirplaySpeak DEBUG pk = 'c8cbc858090e9dfafae0c35155ad6fde841011041bc20bd096f27717b04 0e1d1'
      Feb-16 7:22:40 PM AirplaySpeak INFO Resolved Service: D4909CCD6E5B - Kitchen - 192.168.0.43 - 7000
      Feb-16 7:22:40 PM AirplaySpeak INFO Found Service: D4909CCD6E5B@Kitchen
      Feb-16 7:22:40 PM AirplaySpeak DEBUG pk = 'ac99a9fed3082f819a1096af860c11a2be4036e55b393f9516246faa8fb fc22b'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG am = 'AppleTV6,2'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG sf = '0x244'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG ft = '0x4A7FFFF7,0x55FDE'
      Feb-16 7:22:40 PM AirplaySpeak INFO Resolved Service: DC56E74BBF8C - Apple TV (2) - 192.168.0.21 - 7000
      Feb-16 7:22:40 PM AirplaySpeak INFO Found Service: DC56E74BBF8C@Apple TV (2)
      Feb-16 7:22:40 PM AirplaySpeak DEBUG vs = '190.9.p6'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG sf = '0x6'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG am = 'AVRX1200W'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG fv = 'p6.1300.0'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG ft = '0x444F8A00'
      Feb-16 7:22:40 PM AirplaySpeak DEBUG et = '0,4'
      Feb-16 7:22:40 PM AirplaySpeak INFO Resolved Service: 0005CD5EB5F6 - Denon AVR-X1200W - 192.168.0.6 - 1041
      Feb-16 7:22:40 PM AirplaySpeak INFO Found Service: 0005CD5EB5F6@Denon AVR-X1200W
      Feb-16 7:22:40 PM AirplaySpeak DEBUG pk = '194df57c6ff7648d67267b82bbb134dcd19a99728eff62ae4af7a454d72 a3093'
      Feb-16 7:22:40 PM AirplaySpeak INFO Resolved Service: DC56E72DF313 - Apple TV - 192.168.0.41 - 7000
      Feb-16 7:22:40 PM AirplaySpeak INFO Found Service: DC56E72DF313@Apple TV
      Feb-16 7:22:39 PM AirplaySpeak INFO AirplaySpeak version 3.0.0.12
      Feb-16 7:22:39 PM Info Plugin AirplaySpeak has connected. IP:127.0.0.1:56182
      Feb-16 7:22:39 PM Plug-In Interface AirplaySpeak is running as a trial, 24 days remaining.
      Feb-16 7:22:30 PM Plug-In Shutting down Plug-In: AirplaySpeak
        here is debug log for trying to have speaker speak something
        Pri Type/Error Message/Source
        Feb-16 7:24:34 PM AirplaySpeak DEBUG 14 Speaker.AfterSend()
        Feb-16 7:24:34 PM AirplaySpeak DEBUG 14 Speaker.SendSample() gets lock
        Feb-16 7:24:34 PM AirplaySpeak DEBUG 14 Speaker.BeforeSend()
        Feb-16 7:24:34 PM AirplaySpeak DEBUG Stack: at RTSPClient.Setup(Int32 controlport, Int32 timingport) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
        Feb-16 7:24:34 PM AirplaySpeak INFO Connection to Kitchen (192.168.0.43:7000) failed: SETUP: no timing_port in response
        Feb-16 7:24:34 PM AirplaySpeak DEBUG Transport, RTP/AVP/UDP;unicast;mode=record;server_port=61770;control_port=50293 ;timing_port=0
        Feb-16 7:24:34 PM AirplaySpeak DEBUG Content-Length, 0
        Feb-16 7:24:34 PM AirplaySpeak DEBUG Session, 1
        Feb-16 7:24:34 PM AirplaySpeak DEBUG Date, Sat, 17 Feb 2018 00:24:24 GMT
        Feb-16 7:24:34 PM AirplaySpeak DEBUG Audio-Jack-Status, connected
        Feb-16 7:24:34 PM AirplaySpeak DEBUG CSeq, 2
        Feb-16 7:24:34 PM AirplaySpeak DEBUG Server, AirTunes/356.19
        Feb-16 7:24:34 PM AirplaySpeak DEBUG SETUP rtsp://192.168.0.10/0259170475 RTSP/1.0 CSeq: 2 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=59902;timing_port=59901 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 1194D2BCF064DDFF
        Feb-16 7:24:34 PM AirplaySpeak DEBUG CSeq, 1
        Feb-16 7:24:34 PM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.0.10/0259170475 RTSP/1.0 CSeq: 1 Content-Type: application/sdp Content-Length: 182 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 1194D2BCF064DDFF v=0 o=iTunes 0259170475 0 IN IP4 192.168.0.10 s=iTunes c=IN IP4 192.168.0.43 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
        Feb-16 7:24:33 PM AirplaySpeak DEBUG 14 Speaker.Reset() gets the lock
        Feb-16 7:24:33 PM TTS Speak: (Kitchen:*):Test Test Test
        Feb-16 7:24:33 PM Sonos SpeakIn called for Device = 0, Text = Test Test Test, Wait=False, Host = Kitchen:*
        Feb-16 7:24:33 PM AirplaySpeak INFO (Kitchen): Test Test Test
        Feb-16 7:24:33 PM Event Event Trigger "Homeseer Home Events airplay test"
        Feb-16 7:24:33 PM Event Event Homeseer Home Events airplay test triggered by the event page 'Run' button.
          please try again with version 3.0.0.13 available here: https://forums.homeseer.com/showthre...48#post1066148
            Thanks it worked for HomePods
            Now is there anyway to change the volume of a homepod like for an event such as at night turn homepod volume to 20 percent.. I don't want to speak something necessarily for this event but just be able to control homepod volume. Also is there a way to control volume of homepod within HSTOUCH?
              Does the volume slider on the config page works on your HomePods?
              If so I could make that available as a device.
                yes the volume slider in config works for my apple home pods
                thanks a device for each would be great!
                  Airplay2 compatibility
                  Hi Spud,
                  I think this thread answer to a question I had. At least partially.
                  I've removed my wired in wall/ceiling speakers and now looking at a Wi-Fi solution with ideally the following objectives :
                  - HS speaks to one or a group of clients (AiplaySpeak I suppose)
                  - Cast iTunes from your plugin to one or a group of clients.
                  - In a perfect world cast Spotify also to one or a group of clients.
                  - Control individual clients volume.
                  For some rooms I'd prefer Bose and others Sonos (Looking at the actual non-Airplay2 market offering)
                  I know that Sonos and Bose have announced Airplay2 support (But still have not seen any)
                  Do you have other preliminary info about how your plug-ins will support Airplay2?
                  So far what I'm thinking is :
                  - Bose PI : Does not seem very flexible
                  - Sonos PI : Might be an option
                  - Chromecast PI : Might be an option
                  Any other taught from anyone appreciated.
                  Regards.
                    Spud,
                    I'm wondering if you can help me somehow with he same issue I'm having with my Homepod, the only difference is I'm using Airplay Speak on HS2, I know it's not supported anymore but would I be able to config it manually to not look for the timing port?
                    Here is my error when it tries to connect to the Homepod.
                    Connection to Living Room (192.168.1.208:7000) failed: SETUP: no timing_port in response
                      Originally posted by tommyd75 View Post
                      Spud,
                      Sorry I don't think there is a way to do that without a code change in the plugin.
