Little error + u can add this client to the list
    getting a error on long speech again, but this time on playing from wav file
    it just drops connection or something...
    even if i do use delay after it drops much quicker..
    but i have no problems when i stream the same file from my phone...
    you can add the ezcast to the list
    regards
    getting this date..
    DEBUG Date, Thu, 01 Jan 1970 00:03:37 +0000
    DEBUG System.IO.IOException: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine. ---> System.Net.Sockets.SocketException: An established connection was aborted by the software in your host machine at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Teardown()
    Mar-25 11:05:45	 	AirplaySpeak	DEBUG TEARDOWN rtsp://192.168.xx.xxx/0719765704 RTSP/1.0 CSeq: 7 Session: DEADBEEF User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: A9359E46698250B5
    Mar-25 11:05:45	 	AirplaySpeak	DEBUG TIMING EXCEPTIONA blocking operation was interrupted by a call to WSACancelBlockingCall
    Mar-25 11:05:45	 	AirplaySpeak	DEBUG System.Exception: Request failed, read error at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Flush(Int32 rtpseq, Int32 rtptime)
    Mar-25 11:05:45	 	AirplaySpeak	DEBUG FLUSH rtsp://192.168.xx.xxx/0719765704 RTSP/1.0 CSeq: 6 Session: DEADBEEF RTP-Info: seq=11452;rtptime=1425806 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: A9359E46698250B
    // i found out a bug on beta 423, when i start the plugin it does find the device in the log but not showing up in the plugin.. so after restart it does not work correct. but it shows up in the plugin again.
    so it only speak this text (this is a test 1 2 3 4) when i do (this is a test 1 2 3) it does not speak so anything lower than that does not work. so (21 characters minimum with counted spaces)
    Mar-25 13:03:56	 	AirplaySpeak	DEBUG TIMING EXCEPTIONA blocking operation was interrupted by a call to WSACancelBlockingCall
    Mar-25 13:03:56	 	AirplaySpeak	DEBUG TEARDOWN rtsp://192.168.x.xxx/2473479959 RTSP/1.0 CSeq: 7 Session: DEADBEEF User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F
    Mar-25 13:03:56	 	AirplaySpeak	DEBUG System.Exception: Request failed, read error at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Flush(Int32 rtpseq, Int32 rtptime)
    Mar-25 13:03:56	 	AirplaySpeak	DEBUG FLUSH rtsp://192.168.xx.xxx/2473479959 RTSP/1.0 CSeq: 6 Session: DEADBEEF RTP-Info: seq=7746;rtptime=2346215 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F
    Mar-25 13:03:56	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:55	 	AirplaySpeak	DEBUG 17 Speaker.OnQueueEnd() gets the lock
    Mar-25 13:03:55	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:53	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:52	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:51	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:50	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:49	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:48	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:47	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:46	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:45	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:44	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:43	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:43	 	SCRAPER	*** Scraper Updated ***
    Mar-25 13:03:42	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:41	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:40	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:39	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:38	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:37	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:36	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:35	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:34	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:33	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:32	 	FileControl	Automatic File Control is Updated
    Mar-25 13:03:32	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:31	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:30	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:29	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:28	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:27	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:26	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:25	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:24	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:23	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:22	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:21	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:20	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:19	 	AirplaySpeak	DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:18	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:17	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:16	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:15	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:14	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:13	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:12	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:11	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:10	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:09	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:08	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:07	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:06	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:05	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:04	 	AirplaySpeak	DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock
    Mar-25 13:03:04	 	AirplaySpeak	DEBUG 16 Speaker.AfterSend()
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG 16 Speaker.SendSample() gets lock
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG 16 Speaker.BeforeSend()
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG Server, AirTunes/220.68
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG Date, Thu, 01 Jan 1970 00:11:50 +0000
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG CSeq, 5
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG SET_PARAMETER rtsp://192.168.x.xxx/2473479959 RTSP/1.0 CSeq: 5 Session: DEADBEEF Content-Type: text/parameters Content-Length: 20 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F volume: -10.000000
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG Audio-Latency, 2205
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG Audio-Jack-Status, connected; type=analog
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG CSeq, 4
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG RECORD rtsp://192.168.xx.xxx/2473479959 RTSP/1.0 CSeq: 4 Session: DEADBEEF Range: npt=0- RTP-Info: seq=1202;rtptime=42727 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG Transport, RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=50752;timing_port=50751;server_port=56588
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG Session, DEADBEEF
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG CSeq, 3
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG SETUP rtsp://192.168.xx.xxx/2473479959 RTSP/1.0 CSeq: 3 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=50752;timing_port=50751 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG CSeq, 2
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG ANNOUNCE rtsp://192.168.xx.xxx/2473479959 RTSP/1.0 CSeq: 2 Content-Type: application/sdp Content-Length: 182 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F v=0 o=iTunes 2473479959 0 IN IP4 192.168.xx.xxx s=iTunes c=IN IP4 192.168.xx.xxx t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG CSeq, 1
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG Public, ANNOUNCE, SETUP, RECORD, PAUSE, FLUSH, TEARDOWN, OPTIONS, GET_PARAMETER, SET_PARAMETER, POST, GET
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG OPTIONS * RTSP/1.0 CSeq: 1 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F
    Mar-25 13:03:03	 	AirplaySpeak	DEBUG 16 Speaker.Reset() gets the lock
    Mar-25 13:03:03	 	AirplaySpeak	INFO (SpeakerClient1): C:\voice.wav
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Bump
