SpeakDev error
    SpeakDev error
    Lately I have received errors in the log as at the end of this message.
    I do not get the usual introductory INFO message like:
    AirplaySpeak INFO (iW3,MFree):xxx
    Error log entries:
    Jan-23 4:00:43 PM Error In SpeakDev calling a speak proxy plug-in, exception is Exception from HRESULT: 0x80045017
    Jan-23 4:00:43 PM SpeakText text Mixed precipitation tomorrow and next Wednesday, with high temperatures falling to 45°F next Wednesday
    Jan-23 4:00:43 PM SpeakText text Air pressure is dropping
    Jan-23 4:00:43 PM SpeakText text Temperatures between 36 and 58
    What could this be?
    Thanks for looking into this,
    Eric
    This error message is thrown by HS3 not by AirplaySpeak.
    Is that possible you have another plugin acting as a speak proxy and causing problems?
    Do you still have this error if you restart AirplaySpeak? if you restart HS3?
      I don't have another plugin as speak proxy, I continue to have this error after restarting.
      I should have mentioned that it mostly happens when I call the plugin several times consecutively. Typically the first few times it works, and then I start getting these errors.
      After I added a wait time between the different calls, the errors stopped occurring. Strange, as I called them with the "wait until speech completes" option.
