Issue Multiple Airplay Speak running
    I was working at the Linux command like level of a project and happen to be running htop. I noticed that there were multiple, like over 50, copies of airplay speak running.
    I shutdown HS3 not all of the instances of APS went away even though all of the HS3 processes did. This leaves me to believe that HS3 lost track of them.
    I did a reboot and found that there were already over 10 running as soon as HS3 came up. Every time I run a speaking event I get additional airplay speaks running. They basicaly just keep getting created every time the system speaks.
    I disabled APS and all instances disappeared in htop but as soon as APS was reenabled a bunch showed up even though there was nothing speaking. I watched for a few minutes and the instances came and went from about 12 to as high as 18. I can understand addition instances might be created whenever something is speaking but not when everything is quite.
    OMT, when I originally found the huge number of instances of APS running and that wouldn't shutdown it was after I found that the airplay device it was accessing was locked up. Don't know why that should keep them running and disconnected from HS3 but it's something that I noticed.
    As I finish this and after a clean HS3 restart there are 12 plus or mins a few and only two things have been spoken.
    I'm currently running HS3 version .500 with APS version 3.0.0.13. I'm about to load the current beta which I think is .531.
    Anyone else seeing this or has an idea why it's happing?
    It is really weird, I have never seen this.
    The plugin never create any other process by itself.
    Could you post a screenshot of what you see exactly?
    What do you have in the logs? Do you see the AirplaySpeak plugin initializing multiple times?
      Logs look clean. The only place I see this is in the top. Been a while since I used ps so I need to find the switch which show the commnad.
Name:	Screen Shot 2019-04-30 at 2.57.10 PM.png
        If you just press shift+H on your keyboard on htop?
