Wondering if anybody can help me out here.
I basically migrated my stuff over from machine 1, to machine 2. My original machine was a VM running Windows 2016, and I recently moved to a Dedicated Server running Windows 10. Everything else carried over well, just this specific plugin. I've deleted everything, configs, etc etc. Reinstalled, no bueno. I've loaded the Bonjour service.
When I try to use the TTS I get the following debug .
Jun-22 9:55:48 AM | AirplaySpeak | DEBUG 21 Speaker.AfterSend() |
Jun-22 9:55:48 AM | AirplaySpeak | DEBUG 21 Speaker.SendSample() gets lock |
Jun-22 9:55:48 AM | AirplaySpeak | DEBUG 21 Speaker.SendSample() |
Jun-22 9:55:48 AM | AirplaySpeak | DEBUG 21 Speaker.BeforeSend() |
Jun-22 9:55:48 AM | AirplaySpeak | DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset() |
Jun-22 9:55:48 AM | AirplaySpeak | INFO Connection to Master Bedroom (192.168.1.107:7000) failed: Request failed, error RTSP/1.0 500 Internal Server Error |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG RECORD rtsp://192.168.1.251/4152896484 RTSP/1.0 CSeq: 3 Session: 1 Range: npt=0- RTP-Info: seq=2739;rtptime=38132 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 776EBE318767230F |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG SETUP: no timing_port in response |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG Transport, RTP/AVP/UDP;unicast;mode=record;server_port=55565;control_port=61913 ;timing_port=0 |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG Content-Length, 0 |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG Session, 1 |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG Date, Sat, 22 Jun 2019 16:55:16 GMT |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG CSeq, 2 |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG Audio-Jack-Status, connected |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG Server, AirTunes/383.1.3 |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG SETUP rtsp://192.168.1.251/4152896484 RTSP/1.0 CSeq: 2 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=61547;timing_port=61546 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 776EBE318767230F |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG CSeq, 1 |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG ANNOUNCE rtsp://192.168.1.251/4152896484 RTSP/1.0 CSeq: 1 Content-Type: application/sdp Content-Length: 184 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 776EBE318767230F v=0 o=iTunes 4152896484 0 IN IP4 192.168.1.251 s=iTunes c=IN IP4 192.168.1.107 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100 |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG 21 Speaker.Reset() gets the lock |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG 21 Speaker.Reset() |
Jun-22 9:55:16 AM | AirplaySpeak | DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset() |
Jun-22 9:55:16 AM | AirplaySpeak | INFO Connection to Kitchen (192.168.1.111:7000) failed: Request failed, error RTSP/1.0 500 Internal Server Error |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG RECORD rtsp://192.168.1.251/3813022426 RTSP/1.0 CSeq: 3 Session: 1 Range: npt=0- RTP-Info: seq=993;rtptime=18666 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 8D9DE3819DDC2DA3 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG SETUP: no timing_port in response |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG Transport, RTP/AVP/UDP;unicast;mode=record;server_port=52047;control_port=55124 ;timing_port=0 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG Content-Length, 0 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG Date, Sat, 22 Jun 2019 16:54:43 GMT |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG Session, 1 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG Audio-Jack-Status, connected |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG CSeq, 2 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG Server, AirTunes/383.1.3 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG SETUP rtsp://192.168.1.251/3813022426 RTSP/1.0 CSeq: 2 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=61544;timing_port=61543 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 8D9DE3819DDC2DA3 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG CSeq, 1 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG ANNOUNCE rtsp://192.168.1.251/3813022426 RTSP/1.0 CSeq: 1 Content-Type: application/sdp Content-Length: 184 User-Agent: iTunes/7.6.2 ( Windows;N Client-Instance: 8D9DE3819DDC2DA3 v=0 o=iTunes 3813022426 0 IN IP4 192.168.1.251 s=iTunes c=IN IP4 192.168.1.111 t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100 |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG 21 Speaker.Reset() gets the lock |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG 21 Speaker.Reset() |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG 37 Speaker.AfterSend() |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG 37 Speaker.SendSample() gets lock |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG 37 Speaker.SendSample() |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG 37 Speaker.BeforeSend() |
Jun-22 9:54:43 AM | AirplaySpeak | DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset() |
Jun-22 9:54:43 AM | AirplaySpeak | INFO Connection to Master Bedroom (192.168.1.107:7000) failed: Request failed, error RTSP/1.0 500 Internal Server Error |
Jun-22 9:54:16 AM | AirplaySpeak | INFO (Kitchen,Master Bedroom): Front Door locked |
