Hi Spud,
I checked and with Airplayspeak plugin activated, the hs3 service takes 55 seconds to stop (stop job on my screen )
But with the plugin deactivated, it take 20 seconds. So 25 secs more ( the other 14 plugins stop in 20 secs ).
Do you think you could check this ? I had the same issue with Kodi ( but do not need/use the plugin for now because i just use one command that i can send directly to the json api)
attached is the log. I did two reboots. But do not think there is any useful data?
