Airplay Speak plug-in general information
This is a sticky topic.
  • #31
    Originally posted by gianbevi View Post
    Hi!
    Can you please explain me how to set different presence announcement in different rooms?
    sure, in HS2 or HS3?
    Basically you just have to add a Speak action, fill the text to be spoken, and fill the host field with the name of the Airplay Speaker you want it to be sent to. If the host field is blank it will be sent to all speakers.
    See at the end of this user guide there is a screenshot with an example:
    http://board.homeseer.com/showthread.php?t=158680
    • #32
      Thank you
      Inviato dal mio iPad utilizzando Tapatalk
      • #33
        Another question
        Do you know where to download a tts voice in Italian?
        The provided voices doesn't speak well Italian phrases...
        • #34
          Another question
          No, sorry, I don't know where to find some good italian voices.
          Personally, I use the french Loquendo voices. I don't know if they have italian voices as well.
          I think your best shot is to search in HS forums or in google. any voice that works with windows and/or with the HS speaker client should work with this plugin.
          • #35
            Another question
            Try http://www.ivona.com/ I use the British voices and they are good but I dont know Italian so can not comment on that. There is a demo on the website.
            Greig.
            Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
            Scripts =
            Various
            • #36
              This is fantastic and......free!!
              http://dimio.altervista.org/ita/
              • #37
                Sorry for all these questions but I have other two....
                1. How to auto log on iTunes when homeseer starts?
                2. When I try to add a button on hstouch to control speakers nothing happens...
                In the function of the button I have control homeseer device...kitchen for example
                What am I doing wrong?
                Sorry for my English
                • #38
                  This is the forum for AirPlay Speak plugin which has almost nothing to do with iTunes.
                  If you need a plugin to control iTunes and Airplay speakers within iTunes, look at the iTunes DAAP plugin: http://board.homeseer.com/forumdisplay.php?f=1147
                  • #39
                    Question
                    Question:
                    What happens if someone else is already using the airplay device to play music? Will I hear the HS anouncement mixed in with the music, or will homeSeer get a Device Busy?
                    • #40
                      Originally posted by rsisson View Post
                      Question:
                      For me, it takes over the device. It stops the music, then plays the message. You have to restart the music after the message is complete.
                      • #41
                        Will this and how will this work with air play 2 and specifically Apple Home pod?
                        • #42
                          Hard to say, there is very little technical information available about Airplay 2, and as far as I know it's not even activated yet on latest iOS.
                          If this is easy enough to do, I will make this plugin compatible with Airplay 2 devices.
