Error on startup
    Error on startup
    Spud,
    Am getting the following error on startup of HS:
    3/9/2013 11:50:01 AM Plug-In Initializing Plug-in: AirplaySpeak
    3/9/2013 11:50:01 AM Error Initializing interface: AirplaySpeak-HSPI::InitIO: Failed to init: Exception: System.Exception: No Zeroconf providers could be found or initialized. Necessary daemon may not be running. at Mono.Zeroconf.Providers.ProviderFactory.GetProviders() at Mono.Zeroconf.Providers.ProviderFactory.get_DefaultProvider( ) at Mono.Zeroconf.Providers.ProviderFactory.get_SelectedProvider () at Mono.Zeroconf.ServiceBrowser..ctor() at HSPI_AIRPLAY_SPEAK.AirplaySpeakApp.StartDiscoveryOfAirplaySp eakers() at HSPI_AIRPLAY_SPEAK.AirplaySpeakApp.Init() at HSPI_AIRPLAY_SPEAK.HSPI.InitIO(Int64 port)
    3/9/2013 11:50:01 AM Plug-In Finished initializing plug-in AirplaySpeak
    I am running 64 bit Windows 7 and HS .75.
    Thoughts?
    Chris
    Looks like there is one dll missing. Make sure you have Mono.Zero.conf.Providers.Bonjour.dll in your Homeseer directory.
    If you have it, maybe it fails to load on your system for some reason...
    In any case try to reinstall the plugin.
      or most probably you don't have the Apple Bonjour service installed/running.
      Sorry I completely overlooked that, because it's automatically installed with iTunes, and all my testing machines have iTunes installed.
      Let me try to find you a link where you can download it
        Back from an errand. You are correct this system does not have itunes. Will install iTunes and see if that is the fix.
        Stand by.
        Chris
          here is the bonjour installer for Win 64bits
          https://www.dropbox.com/s/a0lhdxpbd19go4i/Bonjour64.msi
          and here is the one for Win 32Bits
          https://www.dropbox.com/s/dkoi00zvlhxx2cn/Bonjour.msi
          Please let me know if that fix your problem.
            Yep, it did. Found the Airport Express that I am testing with as well as a VSX-1122 Amp and an Apple TV. Only the Airport Express will work (expected). Will continue to play and let you know if anything else comes up.
            Chris
              Team,
              How do I install bonjour on my linux container?
