List of compatible speakers
This is a sticky topic.
  • List of compatible speakers
    Does anyone have a list of compatible Airplay speakers that work with this Plug-in?
    Good idea! Let's create a list of compatible devices (hardware and software) that I will try to keep up to date:
    • AppleTV
    • AirPort Express
    • Shairport4w
    • Kodi/XBMC
    • Pioneer Receiver VSX 1121, VSX 921
    • Pioneer A1 Wi-Fi Speaker
    • Denon AVR 2313
    • Yamaha V673 receiver
    • Phillips Airplay speakers
    • Raspberry Pi + RasPlex
    • Cydia's AirPlay Server
    • AirBubble
    Note: most of AirPlay capable devices are compatible with this plugin, if you have one that is not listed here it's probably because nobody has tested it yet. If you successfully test one device that is not listed here, please report it in this thread and I will update the list. If you find one that is not compatible, please create a new thread describing the problem, and I will try to fix it.
      I have a Denon 2313 unit which has AirPlay. AirPlaySpeak does work with this but the speech is somewhat slow. The Denon responds to AirPlay even when it's switched off: in this case AirPlaySpeak still works but by the time the AirPlay protocol activates the Denon unit, the first 6-7 words of the phrase sent to it by AirPlaySpeak are lost. If the Denon is already switched on, there is no such loss.
        as said in the other thread, there is a "Before delay" setting in the config page that you should try. Let us know if that fix your problem.
        I'm adding Denon 2313 to the list of compatible hardware.
          My Yamaha V673 receiver works fine too.
            The Pioneer Receiver VSX 921 is also working fine (=similair to 1121).
              Cydia's AirPlayServer works also fine. It's not an app but after install you'll have to activate it in Settings, like a service..? It works only as an audio receiver and you don't have to worry about if the program is active (in the background) or not.
                cool, it works on any iOS jailbroken device, right?
                added it to the list
                  I'm testing shairport-sync on the Raspberry Pi, currently a RBPi 3 and next a RBPi Zero, and it seems to work just fine. Currently only using the builtin audio but will be checking out various audio cards but I don't expect any that will change anything other than better sound.
                  I've only found two things one needs to be aware of.
                  • Shairport-sync is listed as unknown. Question, what's missing that would allow shairport-sync to be identified rather than being listed as unknown? If that can be identified I can post on Github asking that it be added to shairport-sync.
                  • By default, shairport-sync rejects any other Airplay device from connecting once any connection is up. You have to drop the existing connection then shairport-sync will allow the other stream to connect where other Airplay devices, as I understand it, will shutdown the existing connection. When this happens AirplaySpeak logs the following error. Don't know if this conditions could be detected such that a more informative error could be entered into the log.
                    Jan-17 6:47:09 AM AirplaySpeak INFO Connection to Raspberrypi (10.0.1.16:5000) failed: Request failed, error RTSP/1.0 453 Unauthorized
                    That said the default action can be changed so that you can interrupt the current connection. See the documentation on Github.
                  So right now if you want a single box to be able to play both an AirPlay music stream and still receive AirplaySpeak you need two RBPi Zeros and an audio mixer.
                  I'd love to see shairport-sync modified so two threads could be running at the same time, with each bonded to a different IP address on the same interface, and their outputs mixed. One would be the priority channel and the other the secondary channel. This would, for example, allow AirplaySpeak to connect to the priority channel even if you're playing music on the secondary channel.
                  If done correctly when the primary channel receives a connection it would lower or mute the volume on the secondary channel.
                  I'm going to request this on the shairport-sync Github channel and see what they say. If not then I may look at doing it myself.
                  I do have a question, does AirplaySpeak synchronize its output when feeding multiple Airplay devices using the syncing built into Airplay? Don't really care about syncing to Speaker Clients when you have AirplaySpeak
                  HomeSeer Version: HS3 Standard Edition 3.0.0.531 | Mono JIT compiler version 5.20.1.19 (tarball Thu Apr 11 09:02:17 UTC 2019)
                  Linux version: Linux auto 4.15.0-48-generic #51-Ubuntu SMP Wed Apr 3 08:28:49 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
                  IP Address: 10.0.2.16 | Number of Devices: 417 | Number of Events: 667 | Available Threads: 399 | HSTouch Enabled: True
                  Enabled Plug-Ins: AirplaySpeak: 3.0.0.13 | BLBackup: 2.0.61.0 | EasyTrigger: 3.0.0.65 | LiftMaster MyQ: 1.3.7006.42100
                  mcsMQTT: 4.0.2.2 | PHLocation2: 3.0.0.53 | Pushover 3P: 0.0.0.45 | Z-Wave: 3.0.1.262
                  Z-Net version: 1.0.23 using a HomeSeer SmartStick+: 6.04 (ZDK 6.81.3)
                    Has anyone tried this plug-in with an Apple HomePod?
                      as I said in the other thread csullivan tested it successfully with a Home
                      pod: https://forums.homeseer.com/showthre...27#post1351827
