I'm just busy adding the AirPlay functionality of my 'Apple airport express' to Homeseer.
I installed the ' iTunes Speaker' plugin, this all works perfectly. The next step must be 'AirplaySpeak' to let Homeseer Speak over my Airplay devices.
When homeseer starts up everything seems to be fine, the folowing text appears in the LOG:
6/27/2013 10:47:23 PM - AirplaySpeak - Resolved Service: 20C9D09E2A2A - LivingRoom - 10.0.1.1 - 5000
6/27/2013 10:47:23 PM - AirplaySpeak - TXT Records =
6/27/2013 10:47:23 PM - AirplaySpeak - txtvers = '1'
6/27/2013 10:47:23 PM - AirplaySpeak - ch = '2'
6/27/2013 10:47:23 PM - AirplaySpeak - cn = '0,1'
6/27/2013 10:47:23 PM - AirplaySpeak - et = '0,4'
6/27/2013 10:47:23 PM - AirplaySpeak - sv = 'false'
6/27/2013 10:47:23 PM - AirplaySpeak - da = 'true'
6/27/2013 10:47:23 PM - AirplaySpeak - sr = '44100'
6/27/2013 10:47:23 PM - AirplaySpeak - ss = '16'
6/27/2013 10:47:23 PM - AirplaySpeak - pw = 'false'
6/27/2013 10:47:23 PM - AirplaySpeak - vn = '65537'
6/27/2013 10:47:23 PM - AirplaySpeak - tp = 'TCP,UDP'
6/27/2013 10:47:23 PM - AirplaySpeak - vs = '105.1'
6/27/2013 10:47:23 PM - AirplaySpeak - am = 'AirPort10,115'
6/27/2013 10:47:23 PM - AirplaySpeak - fv = '76300.7'
6/27/2013 10:47:23 PM - AirplaySpeak - sf = '0x5'
When i run the default ' Speak Time' event, the 'Computer' speaks the time, but the 'Airport Express/Airplay' doesn't do anthing. After a few seconds the folowing apears in the LOG:
6/27/2013 10:51:49 PM - AirplaySpeak - ANNOUNCE rtsp://10.0.1.14/3915479145 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 175User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 574C2653FC0BE268v=0o=iTunes 3915479145 0 IN IP4 10.0.1.14s=iTunesc=IN IP4 10.0.1.1t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
6/27/2013 10:51:49 PM - AirplaySpeak - CSeq, 1
6/27/2013 10:51:49 PM - AirplaySpeak - Server, AirTunes/105.1
6/27/2013 10:51:49 PM - AirplaySpeak - SETUP rtsp://10.0.1.14/3915479145 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=58376;timing_port=58375User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 574C2653FC0BE268
6/27/2013 10:51:49 PM - AirplaySpeak - Transport, RTP/AVP/UDP;unicast;mode=record;server_port=6000;control_port=6001;t iming_port=6002
6/27/2013 10:51:49 PM - AirplaySpeak - CSeq, 2
6/27/2013 10:51:49 PM - AirplaySpeak - Session, 1
6/27/2013 10:51:49 PM - AirplaySpeak - Audio-Jack-Status, connected; type=analog
6/27/2013 10:51:49 PM - AirplaySpeak - RECORD rtsp://10.0.1.14/3915479145 RTSP/1.0CSeq: 3Session: 1Range: npt=0-RTP-Info: seq=5263;rtptime=2750User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 574C2653FC0BE268
6/27/2013 10:52:22 PM - AirplaySpeak - Connection to LivingRoom (10.0.1.1:5000) failed: Request failed, error 500
6/27/2013 10:52:22 PM - AirplaySpeak - Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
Can anyone help me finding the problem?
Jaco
Jaco
