IPOD's
  • IPOD's
    I figured when I read all the Apple stuff this might work on my Ipod.
    I guess it won't or I have something wrong. I get this error.
    6/28/2013 3:18:16 PM ~!~Error~!~Calling GenPage for plugin, link: /airplayspeak_config Error: Could not load file or assembly 'System.Speech, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
    6/28/2013 3:18:18 PM ~!~Error~!~Calling GenPage for plugin, link: /airplayspeak_config Error: Could not load file or assembly 'System.Speech, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
    No, Im from Iowa. I only work in outer space. Captain Kirk
    the error from your log shows that the system cannot load the speech synthesis engine.
    what is the .NET framework installed on your HS machine?
    does the HS speaker client work on your HS machine?
    when does this error appear?
    what is the version of the Airplay plugin you are testing?
    this is probably not related with the error you see, but I 'm not sure to understand what you are trying to do with your ipod. Are you trying to send some HS annoucements to your iPod? What kind of iPod is it?
      2.0 and 4.0
      yes 2.5.0.80
      As soon as I click the "Config" button in the Interfaces tab.
      Latest from the Updater
      Yes, I want to hear what HS says on my Ipod. It is a Ipod Touch iOS ver 6.1.3
      Tim
        Do I have to add more items to the Scripting References section of the settings.ini ?
        Tim
          .NET 2.0, 3.0, 3.5 uses CLR 2.0 (CLR = Common Language Runtime)
          .NET 4.0 uses CLR 4.0
          so my guess is that as HS2 target .NET 2.0, the CLR used is 2.0, but as you don't have 3.0 or 3.5 installed the System.Speech assembly does not exist on your system.
          so you need to install .NET 3.0 or 3.5
          alternatively I can provide an old version of the plugin which does not use this System.Speech assembly, but the quality of the speech synthesis will be low.
          also, I don't think the iPod Touch is natively an AirPlay receiver (it is an AirPlay sender), so it probably won't work unless you install an app which adds this capability.
