Serious problem. Can't adjust the volume on an action.
  • Serious problem. Can't adjust the volume on an action.
    I've scoured the documentation, but there doesn't appear to be a way to change the volume in an individual speak action. I have different types of notifications. Some are informational and need to be spoken in a low volume. Emergency or security events need to be spoken loudly.
    Also, I use a 6 zone amp with airplay zones throughout the house. The zones are auto on triggered by the input. If they are off, i.e. not used for 4 minute which I keep track in hs, I play a warmup sound like a beep. It needs to be played at the same volume in all zones yet each zone has it's own volume setting in the airplay speak config.
    Is there no tag I can add to the to play text and audio files at a specific volume for that action????
    For example, using:
    <volume level="100">
    This text should be spoken at volume level one hundred.
    </volume>
    which is the standard TSS tag for setting volume is completely ignored and the entire text including the tags are spoken.
      there is a scripting function you can use to set the volume of a speaker to a specific level:
      void SetSpeakerVolume(string name, int volume)
        Originally posted by sorka View Post
        For example, using:
        </volume>
        I may implement this volume tag if this is something that already work with HS speakers.
        Where did you find out about this tag, I can't find it in the HS docs?
          It's part of Microsoft's SAPI TTS XML.
            Something like:
            &hs.SetSpeakerVolume("Garage", 100)
              Oh, wait. I found your example. Trying it now.
                Hmm, so if I run this in the script window:
                &hs.Plugin("AirplaySpeak").SetSpeakerVolume("Side Room / Office", -30)
                I get the following error:
                1/19/2014 10:57:12 AM Event Running script statement immediately: &hs.Plugin("AirplaySpeak").SetSpeakerVolume("Side Room / Office", -30)
                1/19/2014 10:57:12 AM Error Running script, init error: Object required: 'hs.Plugin(...)'
                  If I run it inside a .vbs:
                  Sub Main(parm as object)
                  End Sub
                  I get this error:
                  1/19/2014 12:10:30 PM Event Delayed event execution skipped, the conditions applied were not met: Airplay:Warmup Airplay
                  1/19/2014 12:10:30 PM Event Running script in background: SpeakerVolume.vbs
                  1/19/2014 12:10:30 PM Error Running script, script run or compile error in file: SpeakerVolume.vbs1006:Expected ')' in line 1 More info: Expected ')'
                    End Sub
                    I get this error:
                    try to pu the same lines inside a .vb instead of a .vbs
                      Yup. That worked. Thanks!
