Errors with V 3.0.0.4 On HS3 Pro Edition 3.00.68 - Solved!
    I have 3 Airport Expresses and Getting the following error (uploaded as txt file as well:
    _____________________________________
    Feb-18 7:06:08 PM AirplaySpeak DEBUG 14 Speaker.AfterSend()
    Feb-18 7:06:08 PM AirplaySpeak DEBUG 14 Speaker.SendSample() gets lock
    Feb-18 7:06:08 PM AirplaySpeak DEBUG 14 Speaker.BeforeSend()
    Feb-18 7:06:08 PM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
    Feb-18 7:06:08 PM AirplaySpeak INFO Connection to BACKYARD (10.0.1.1:5000) failed: Request failed, error RTSP/1.0 500 Internal Server Error
    Feb-18 7:05:36 PM AirplaySpeak DEBUG RECORD rtsp://10.0.1.33/4210302718 RTSP/1.0CSeq: 3Session: 1Range: npt=0-RTP-Info: seq=4031{0x3B}rtptime=5963User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: DD902472F2AD2FF7
    Feb-18 7:05:36 PM AirplaySpeak DEBUG Audio-Jack-Status, connected{0x3B} type=digital
    Feb-18 7:05:36 PM AirplaySpeak DEBUG Session, 1
    Feb-18 7:05:36 PM AirplaySpeak DEBUG Server, AirTunes/105.1
    Feb-18 7:05:36 PM AirplaySpeak DEBUG Transport, RTP/AVP/UDP{0x3B}unicast{0x3B}mode=record{0x3B}server_port=6000{0x3B }control_port=6001{0x3B}timing_port=6002
    Feb-18 7:05:36 PM AirplaySpeak DEBUG CSeq, 2
    Feb-18 7:05:36 PM AirplaySpeak DEBUG SETUP rtsp://10.0.1.33/4210302718 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP{0x3B}unicast{0x3B}interleaved=0-1{0x3B}mode=record{0x3B}control_port=58901{0x3B}timing_port= 58900User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: DD902472F2AD2FF7
    Feb-18 7:05:36 PM AirplaySpeak DEBUG CSeq, 1
    Feb-18 7:05:36 PM AirplaySpeak DEBUG ANNOUNCE rtsp://10.0.1.33/4210302718 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 175User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: DD902472F2AD2FF7v=0o=iTunes 4210302718 0 IN IP4 10.0.1.33s=iTunesc=IN IP4 10.0.1.1t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
    Feb-18 7:05:36 PM AirplaySpeak DEBUG 14 Speaker.Reset() gets the lock
    Feb-18 7:05:36 PM AirplaySpeak DEBUG Stack: at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Record(Int32 rtpseq, Int32 rtptime) at RAOPClient.Connect() at HSPI_AIRPLAY_SPEAK.Speaker.Reset()
    Feb-18 7:05:36 PM AirplaySpeak INFO Connection to OFFICE (10.0.1.3:5000) failed: Request failed, error RTSP/1.0 500 Internal Server Error
    Feb-18 7:05:03 PM AirplaySpeak DEBUG RECORD rtsp://10.0.1.33/3943685454 RTSP/1.0CSeq: 3Session: 1Range: npt=0-RTP-Info: seq=4816{0x3B}rtptime=38255User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: F9E00A93D6D1A6C3
    Feb-18 7:05:03 PM AirplaySpeak DEBUG Audio-Jack-Status, connected{0x3B} type=analog
    Feb-18 7:05:03 PM AirplaySpeak DEBUG Session, 1
    Feb-18 7:05:03 PM AirplaySpeak DEBUG Server, AirTunes/105.1
    Feb-18 7:05:03 PM AirplaySpeak DEBUG Transport, RTP/AVP/UDP{0x3B}unicast{0x3B}mode=record{0x3B}server_port=6000{0x3B }control_port=6001{0x3B}timing_port=6002
    Feb-18 7:05:03 PM AirplaySpeak DEBUG CSeq, 2
    Feb-18 7:05:03 PM AirplaySpeak DEBUG SETUP rtsp://10.0.1.33/3943685454 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP{0x3B}unicast{0x3B}interleaved=0-1{0x3B}mode=record{0x3B}control_port=58898{0x3B}timing_port= 58897User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: F9E00A93D6D1A6C3
    Feb-18 7:05:03 PM AirplaySpeak DEBUG CSeq, 1
    Feb-18 7:05:03 PM AirplaySpeak DEBUG ANNOUNCE rtsp://10.0.1.33/3943685454 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 175User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: F9E00A93D6D1A6C3v=0o=iTunes 3943685454 0 IN IP4 10.0.1.33s=iTunesc=IN IP4 10.0.1.3t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
    Feb-18 7:05:03 PM AirplaySpeak DEBUG 14 Speaker.Reset() gets the lock
    Feb-18 7:05:03 PM TTS Speak: (*:*):Test airplay as it does not seem to be working
    Feb-18 7:05:03 PM AirplaySpeak INFO (OFFICE,BACKYARD): Test airplay as it does not seem to be working
    Feb-18 7:05:03 PM Event Event Trigger "Stereo Airplay"
    Feb-18 7:05:03 PM Event Event Stereo Airplay triggered by the event page 'Run' button.
    _________________________________________________
    Please let me know if I can provide more detail or a solution to resolve the issue.
    Sorry if this is a repost, could not find the one I just postef
    Steven G
    Issue has been resolved it was a firewall problem.
    This is a great product
