So when music is playing and an announcement is coming through, it stops for the announcement then does not start back up. Is there a fix for that?
stopping/restarting music
in the config page you can choose an event to run just before an announcement and right after it, so for example if you use iTunes to play some music on your Airplay speakers, you can use an iTunes plugin to pause the music and then resume it
see this thread for an example, it's for HS2 but the same thing is possible using HS3 and the iTunes DAAP plugin.
http://board.homeseer.com/showthread.php?t=159797Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
Originally posted by kideon View PostYeah I tried that manually it didn't resume. I had to turn on and off sharing for the Apple TV.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Just tested it again the above is defintely happening. The only variable is I haven't tried is what you recommended..stopping the music and starting it again before and after the speech. The thing is I wouldn't want to play it if it weren't playing before is there a way to have maybe a global variable set in a script to determine that status and then be read. Could be the same script guess all centered around playing status.
Originally posted by kideon View PostJust tested it again the above is defintely happening. The only variable is I haven't tried is what you recommended..stopping the music and starting it again before and after the speech. The thing is I wouldn't want to play it if it weren't playing before is there a way to have maybe a global variable set in a script to determine that status and then be read. Could be the same script guess all centered around playing status.
Then after the speech you can have another script that check the global variable and resume the music if needed. But to implement this you'd need both AirplaySpeak and iTunes DAAP plugin.
One strange thing is that on my Airport Express if I play some music using iTunes, and I try to send an annoucement it doesn't work and keep playing the music. I have to stop the music before the announcement, for the speech to be spoken.
I don't have an AppleTV to test with, but from what you say I guess the AppleTV has a different behavior.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Sounds fixable either way. Was going to invest in that plugin eventually, trying to figure out my environment. It's a hodgepodge of devices with iTunes serving music.
Haven't really scripted yet might could use some help. Running shairport clients on my android tablets haven't yet tried to see what happens there since hs touch is running in the background (so you get music and spoken announcements)
The problem I have with my Apple-TV, is that it's quite slow to come out of standby mode.
I need to add a 20 sec delay to be certain it will be up to play the announcement.
But then all announcements are delayed 20 sec, even if the Apple-TV is alive and not in standby mode.
I don't know if Apple provides a way to know if the Apple-TV is in standby and has to boot up.--
stipus
it's already a feature of the iTunes DAAP plugin, if it isn't working, tell me exactly what happens and get me some debug logsPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
ok specific to pausing music when speaking it doesn't work. The option is checked but iTunes keeps playing and the music is interrupted, speech comes out (sometimes completely sometimes clipped) and then the clients are silent following. I then have to disable and re-enable the speaker to get music to come back up (pausing and un-pausing sometimes works)
Follow up post with logs. The other issue I was asking about is resuming the playback after speech, seeing if there is an integrated solution possible for that.
Jul-10 10:13:59 AM iTunesDAAP DEBUG Speaker Device Found: D61244431415
Jul-10 10:13:59 AM iTunesDAAP DEBUG Speaker Device Found: 95743386DDCE
Jul-10 10:13:59 AM iTunesDAAP DEBUG Speaker Device Found: 28E7CFDF6BFB
Jul-10 10:13:59 AM iTunesDAAP DEBUG Speaker Device Found: 0
Jul-10 10:13:59 AM iTunesDAAP DEBUG Speaker Device Found: 54271EEF04F5
Jul-10 10:13:59 AM AirplaySpeak DEBUG TEARDOWN rtsp://192.168.2.101/0856492779 RTSP/1.0CSeq: 6Session: 1User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 862B2A23ED7ADC6D
Jul-10 10:13:59 AM AirplaySpeak DEBUG RTP-Info, rtptime=180209
Jul-10 10:13:59 AM AirplaySpeak DEBUG Server, AirTunes/200.54
Jul-10 10:13:59 AM AirplaySpeak DEBUG CSeq, 5
Jul-10 10:13:59 AM AirplaySpeak DEBUG FLUSH rtsp://192.168.2.101/0856492779 RTSP/1.0CSeq: 5Session: 1RTP-Info: seq=664{0x3B}rtptime=180561User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 862B2A23ED7ADC6D
Jul-10 10:13:58 AM AirplaySpeak DEBUG 44 Speaker.OnCheckStatusTimerEvent() gets the lock
Jul-10 10:13:58 AM iTunesDAAP DEBUG State Updated
Jul-10 10:13:58 AM AirplaySpeak DEBUG TEARDOWN rtsp://192.168.2.101/3952773615 RTSP/1.0CSeq: 6Session: BlarghUser-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 8C161DAE7D4D980F
Jul-10 10:13:58 AM AirplaySpeak DEBUG CSeq, 5
Jul-10 10:13:58 AM AirplaySpeak DEBUG Audio-Jack-Status, connected{0x3B} type=analog
Jul-10 10:13:58 AM AirplaySpeak DEBUG FLUSH rtsp://192.168.2.101/3952773615 RTSP/1.0CSeq: 5Session: BlarghRTP-Info: seq=5774{0x3B}rtptime=178462User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 8C161DAE7D4D980F
Jul-10 10:13:58 AM AirplaySpeak DEBUG TEARDOWN rtsp://192.168.2.101/2230704002 RTSP/1.0CSeq: 6Session: BlarghUser-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: AC0D8BF43A40ED66
Jul-10 10:13:58 AM AirplaySpeak DEBUG FLUSH rtsp://192.168.2.101/2230704002 RTSP/1.0CSeq: 5Session: BlarghRTP-Info: seq=7658{0x3B}rtptime=181518User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: AC0D8BF43A40ED66
Jul-10 10:13:58 AM AirplaySpeak DEBUG 37 Speaker.OnQueueEnd() gets the lock
Jul-10 10:13:58 AM AirplaySpeak DEBUG 38 Speaker.OnQueueEnd() gets the lock
Jul-10 10:13:58 AM AirplaySpeak DEBUG 40 Speaker.OnQueueEnd() gets the lock
Jul-10 10:13:57 AM AirplaySpeak DEBUG 43 Speaker.OnCheckStatusTimerEvent() gets the lock
Jul-10 10:13:57 AM AirplaySpeak DEBUG 44 Speaker.OnCheckStatusTimerEvent() gets the lock
Jul-10 10:13:56 AM AirplaySpeak DEBUG 44 Speaker.OnCheckStatusTimerEvent() gets the lock
Jul-10 10:13:56 AM AirplaySpeak DEBUG 43 Speaker.OnCheckStatusTimerEvent() gets the lock
Jul-10 10:13:55 AM AirplaySpeak DEBUG 43 Speaker.OnCheckStatusTimerEvent() gets the lock
Jul-10 10:13:55 AM AirplaySpeak DEBUG 44 Speaker.OnCheckStatusTimerEvent() gets the lock
Jul-10 10:13:54 AM AirplaySpeak DEBUG 44 Speaker.OnCheckStatusTimerEvent() gets the lock
Jul-10 10:13:54 AM AirplaySpeak DEBUG 42 Speaker.AfterSend()
Jul-10 10:13:54 AM AirplaySpeak DEBUG 42 Speaker.SendSample() gets lock
Jul-10 10:13:54 AM AirplaySpeak DEBUG 42 Speaker.BeforeSend()
Jul-10 10:13:54 AM AirplaySpeak DEBUG CSeq, 4
Jul-10 10:13:54 AM AirplaySpeak DEBUG Audio-Jack-Status, connected{0x3B} type=analog
Jul-10 10:13:54 AM AirplaySpeak DEBUG SET_PARAMETER rtsp://192.168.2.101/3952773615 RTSP/1.0CSeq: 4Session: BlarghContent-Type: text/parametersContent-Length: 18User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 8C161DAE7D4D980Fvolume: 0.000000
Jul-10 10:13:54 AM AirplaySpeak DEBUG CSeq, 3
Jul-10 10:13:54 AM AirplaySpeak DEBUG RECORD rtsp://192.168.2.101/3952773615 RTSP/1.0CSeq: 3Session: BlarghRange: npt=0-RTP-Info: seq=5315{0x3B}rtptime=16894User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 8C161DAE7D4D980F
Jul-10 10:13:54 AM AirplaySpeak DEBUG Transport, RTP/AVP/UDP{0x3B}unicast{0x3B}interleaved=0-1{0x3B}mode=record{0x3B}control_port=65022{0x3B}timing_port= 65021{0x3B}server_port=6147
Jul-10 10:13:54 AM AirplaySpeak DEBUG CSeq, 2
Jul-10 10:13:54 AM AirplaySpeak DEBUG Session, Blargh
Jul-10 10:13:54 AM AirplaySpeak DEBUG SETUP rtsp://192.168.2.101/3952773615 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP{0x3B}unicast{0x3B}interleaved=0-1{0x3B}mode=record{0x3B}control_port=65022{0x3B}timing_port= 65021User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 8C161DAE7D4D980F
Jul-10 10:13:54 AM AirplaySpeak DEBUG Apple-Response, IwMYxjkn8MAUXgzlGoLVcVRyfDMASvYFPJIrpeNXArwQCJ/EyKbAq019eS+pY7U0xPaSW/4pYpLnBCgLfs0+tqO5PskvoMzcEjrnE7Lj0waarxftQ1T4pJlwArR8Jo1S78 Nh8fVeDyvAA8NiGamAhyujG0vy78Ft4ixfS/2Rmwn8USlNcHHwsREYHSVlOyLCcKRnv657sArGsikI6+cz2KsDYlFiZGSHrF 1RaNH6Z7tUh3R1C4s5kGPFlKv33odBf7o+5LrJaUWs8jlTB9nhExv58NJ0r/O2PzyJZhWSpM78JYB6Z6dZ8oS8gG1fz/ewlDMRFoaR6oR6NDuXpH6nyA
Jul-10 10:13:54 AM AirplaySpeak DEBUG CSeq, 1
Jul-10 10:13:54 AM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.2.101/3952773615 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 571User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 8C161DAE7D4D980FApple-Challenge: 8p/GVn6sjxmPpcsUpQdHygv=0o=iTunes 3952773615 0 IN IP4 192.168.2.101s=iTunesc=IN IP4 192.168.2.91t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100a=rsaaeskey:eVB/YZHFyxAfbyDAVge2cS/sGecZyHD9dJdOVOLQQH3opNvyozGPeT2moPp0eTlFGWPZl30V0AEPpXclSqU cT93tL7jfyig9irIYf40grnZIQOKmJZmZemTInnt3z8rkCr69uoMgbccOJAC o/KStVZNmuyA/jbzWbZHOaL4tYTQfQ72Fnlbq4ylpFUVpv5pbptZPU+2tTEX/WrPhDVglJkHcSsrIiVKXIx139PSnNi86gd3GMXlTY1iWgqytuYZHIhT/yqXmbSQmRZqNRJ9YyXWLkAEyvq3iu8hNnHBWyc9KHYQq2Ls4UcmL5vtWmkN/YUS2tYikK1Mx1pGON5LSQQa=aesiv:GY3xAQ2vXC5+ZQhmGp231g
Jul-10 10:13:54 AM AirplaySpeak DEBUG 42 Speaker.Reset() gets the lock
Jul-10 10:13:54 AM AirplaySpeak DEBUG SET_PARAMETER rtsp://192.168.2.101/2230704002 RTSP/1.0CSeq: 4Session: BlarghContent-Type: text/parametersContent-Length: 18User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: AC0D8BF43A40ED66volume: 0.000000
Jul-10 10:13:54 AM AirplaySpeak DEBUG RECORD rtsp://192.168.2.101/2230704002 RTSP/1.0CSeq: 3Session: BlarghRange: npt=0-RTP-Info: seq=7199{0x3B}rtptime=19950User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: AC0D8BF43A40ED66
Jul-10 10:13:54 AM AirplaySpeak DEBUG Transport, RTP/AVP/UDP{0x3B}unicast{0x3B}interleaved=0-1{0x3B}mode=record{0x3B}control_port=65019{0x3B}timing_port= 65018{0x3B}server_port=6042
Jul-10 10:13:54 AM AirplaySpeak DEBUG SETUP rtsp://192.168.2.101/2230704002 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP{0x3B}unicast{0x3B}interleaved=0-1{0x3B}mode=record{0x3B}control_port=65019{0x3B}timing_port= 65018User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: AC0D8BF43A40ED66
Jul-10 10:13:54 AM AirplaySpeak DEBUG Apple-Response, NRQCG3u2tFTFJ+K+7G480x8bewM/cowpSf0CxssSyEYXY16xDN/X28edyFtRUmLpIXwwfLCD+Om8Gkf+Hf5rKARf5hrD9RYFBIcuxyopYJuh4xv ExR+gHXyVjQb4DoBElpHiirJeo1fynxtNCecxRzh5eSHJWIrI9UyUBq8mZgY K0/Jm1xGI9gT1HlLZZjkU4eZPRFbtYidj01d2hzVUKcaijG/tdCJMxdXeq/QXdbo8ZU/P/XemTNZUt6SGUeijLL97arSVcdnb1DqoOwufk4xUjCykbtp/wizm2nHcTmFB0UpKEf/RiWLZ9Ulu1YqwGBICOL3TmvTjmEs2TOSVFQ
Jul-10 10:13:53 AM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.2.101/2230704002 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 570User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: AC0D8BF43A40ED66Apple-Challenge: JtVwF24WdSccILp8cnK4qgv=0o=iTunes 2230704002 0 IN IP4 192.168.2.101s=iTunesc=IN IP4 192.168.2.8t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100a=rsaaeskey:JOFek/YCAielftjznmakUt2/PO646gclxbcGFj2haKZ5+BJS6hG6kJYXkN9TOoIpt9aw4gT/TQVkM2frT4F4NAC1GcF0pFHRVe0C893eVW52VUhgM6TP2LIluey885dhfQdl vCHGH5l8hqaCjtxCiRBbW+/CBkCvbh6MOrJkgJyummPBnxRQ2+gNGT6wF8S8AP5ZWbo268mIl/9ydpjZaWw5mB0MwGEkHibfXdwEgBH799/zo4A5jqTQGXrXdITnhOYjRoqfRykpDPLCmLikaoiawMUlgZH5kFIcamU5zIK S/mJkTT5Tzo8iH1E5WS7F8kGzWPSTAAGGGVW60UXxLQa=aesiv:mIOSHocJeV4 PozBno3Gzfw
Jul-10 10:13:53 AM AirplaySpeak DEBUG 42 Speaker.Reset() gets the lock
Jul-10 10:13:53 AM AirplaySpeak DEBUG Server, AirTunes/200.54
Jul-10 10:13:53 AM AirplaySpeak DEBUG CSeq, 4
Jul-10 10:13:53 AM AirplaySpeak DEBUG SET_PARAMETER rtsp://192.168.2.101/0856492779 RTSP/1.0CSeq: 4Session: 1Content-Type: text/parametersContent-Length: 18User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 862B2A23ED7ADC6Dvolume: 0.000000
Jul-10 10:13:53 AM AirplaySpeak DEBUG Audio-Latency, 179
Jul-10 10:13:53 AM AirplaySpeak DEBUG CSeq, 3
Jul-10 10:13:53 AM AirplaySpeak DEBUG RECORD rtsp://192.168.2.101/0856492779 RTSP/1.0CSeq: 3Session: 1Range: npt=0-RTP-Info: seq=205{0x3B}rtptime=18993User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 862B2A23ED7ADC6D
Jul-10 10:13:53 AM AirplaySpeak DEBUG Audio-Jack-Status, connected
Jul-10 10:13:53 AM AirplaySpeak DEBUG Transport, RTP/AVP/UDP{0x3B}unicast{0x3B}mode=record{0x3B}server_port=52540{0x3 B}control_port=51694{0x3B}timing_port=52577
Jul-10 10:13:53 AM AirplaySpeak DEBUG CSeq, 2
Jul-10 10:13:53 AM AirplaySpeak DEBUG Session, 1
Jul-10 10:13:53 AM AirplaySpeak DEBUG SETUP rtsp://192.168.2.101/0856492779 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP{0x3B}unicast{0x3B}interleaved=0-1{0x3B}mode=record{0x3B}control_port=65016{0x3B}timing_port= 65015User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 862B2A23ED7ADC6D
Jul-10 10:13:53 AM AirplaySpeak DEBUG CSeq, 1
Jul-10 10:13:53 AM AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.2.101/0856492779 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 182User-Agent: iTunes/4.6 (Macintosh{0x3B} U{0x3B} PPC Mac OS X 10.3)Client-Instance: 862B2A23ED7ADC6Dv=0o=iTunes 0856492779 0 IN IP4 192.168.2.101s=iTunesc=IN IP4 192.168.2.4t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
Jul-10 10:13:53 AM iTunesDAAP DEBUG State Updated
Jul-10 10:13:53 AM TTS Speak: ():this is a test of the iTunes DAAP plugin
Jul-10 10:13:53 AM AirplaySpeak INFO (Apple TV,gtab,touchpad): this is a test of the iTunes DAAP plugin
Jul-10 10:13:53 AM System Control Panel Immediate Script: &hs.speak "this is a test of the iTunes DAAP plugin"
