airplay error
airplay error
Last edited by Malosa; April 30, 2016, 10:38 AM.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.Tags: None
what kind of device is it exactly?
the fact that you don't see the speaker in the speaker list is normal, you have to add it manually by writing the name of the speaker and then click AddPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
Hi spud ,
Its an ezcast m7
IT works really Well using iT normal , but your plug-in is doing really weird.
After iT Speaks trough homeseer i get the Error , then i need to wait a minute , and iT can speak again , but after speak again that Error.
Looks like a time-out ,but using iT normal i can stream music without no lag
Spud ,
Maybe a stupid question , but can you integrade tuneblade into this plug-in , many people are using iT also
Here is the api
Regards
http://tuneblade.com/Developer/TuneB...API%20v0.8.pdfPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
for your ezcast m7 problem please test version 3.0.0.10 available here
in this same version I have added the possibility to write the log to a file: Logs/AirplaySpeak.txtPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
hi spud ,
I installed it and I tested 2 normal events they work , but when I did try my third long event it stopped talking half way , check debug log
it does not talk anymore..
But he does that only with that long speech event.. Short speeches work normal..
This beta is much better than before , only long speechings don't work.
Delay after : 2 sec.Attached FilesLast edited by Malosa; May 4, 2016, 02:37 PM.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
from your logs it looks like it tries to speak something while the previous speech was not finished.
Could you provide a debug log of one speak action that works and one that doesn't but making sure the previous speak action is finished. ThanksPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
hi spud ,
here they are , the working debug log and not working log
regardsAttached FilesPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
Hi spud , u have any idea about this problem?
Regards
Sended from far far awayPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
Originally posted by Malosa View PostHi spud , u have any idea about this problem?
Regards
Sended from far far awayPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Ok , iT only drops after a long speech , its exactly the same as the topic from virtualpanther: lenght of text announcement
