Pico voice not working - .wav file not found
  • Pico voice not working - .wav file not found
    After I installed some pico (from another thread: http://board.homeseer.com/showthread...ght=pico+voice ), I get the error log below - and no sound... -
    Aug-11 8:44:00 AM AirplaySpeak ERROR File /usr/local/HomeSeer/Temp/AirplaySpeak20160811084400192.wav does not exist
    Aug-11 8:44:00 AM AirplaySpeak INFO (iW3): Volume at 15
    Aug-11 8:44:00 AM AirplaySpeak DEBUG calling SpeakToFile text=Volume at 15 file=/usr/local/HomeSeer/Temp/AirplaySpeak20160811084400192.wav
    Looks like pico puts the file somewhere else?
    Any ideas?
    Eric
    Nobody ran in to this issue yet? I still could not figure out how this can be fixed...
    Any help is welcome!
      are you sure your speak_to_file.sh works?
      did you try to call it from the command line to test?
      speak_to_file.sh test.wav "ths is a test"
        When I enter the command
        speak_to_file.sh test.wav "this is a test"
        in directory
        homeseer@HomeTrollerZeeS2 /usr/local/HomeSeer $
        I get this error message:
        -bash: speak_to_file.sh: command not found
        This is what I had in the speak_to_file.sh:
        ##!/bin/sh
        #flite -o "$1_t" -t "$2"
        #ffmpeg -i "$1_t" -y -ar 44100 "$1"
        #rm "$1_t"
        #!/bin/sh
        pico2wave -l en-US -w "$1" "$2"
        #pico2wave -l en-GB -w "$1" "$2"
        at least when I was testing pico.
        To get the standard voice, I'm using
        #!/bin/sh
        #rm "$1_t"
        ##!/bin/sh
        #pico2wave -l en-US -w "$1" "$2"
        ##pico2wave -l en-GB -w "$1" "$2"
          if I run
          pico2wave -l en-US -w test.wav "this is a test"
          it creates the test.wav file OK in the directory where I run it.
          Seems to me that that's as expected. Not sure why it doesn't put the output file in the right spot for the plugin to pick it up.
