Problems After upgrade to 2.0.15
  • Problems After upgrade to 2.0.15
    Don't know if you want this here or on your web site.
    After upgrading to latest version, AB8SS stopped functioning. Reverting back to previous version and all is well. Log inclosed.
    Thanks.
    Don
    Can you try 2.0.16
    Cheers,
    Bob
      Hi Bob:
      2.0.16 has same issues. Log attached.
      If I remember correctly I had the same problem with this plugin not releasing the COM port as I was having in your BLDenon plugin. You resolved that with a Open/Close button on the status page.
      Don
        Wow that is odd because none of the serial port communication code changed at all
        I am checking into it
        Can you give me another log from plugin startup
        Edit ini and change debugLevel=true and save INI
        Then start plugin
        Cheers,
        Bob
          Here you go. There are two logs, one from 2.0.13 which works, and 2.0.16 which does not work.
          Don
            Did this get resolved? I am wanting to upgrade to the latest. .13 seems to be very slow.
            -Skybolt
              Not yet, I'm afraid. I think Bob is still looking into it.
              Don
                Just FYI, I'm having the same issue. Looking forward to a fix.
                Regards, Bob
