Still Having Issues
  • Still Having Issues
    Bob,
    Having an issue with controlling them (2) in HS3, was rock solid in HS2 but sometimes (allot recently) it fails to control individual speakers through events. I have to click it several times?
    Thom
    What are you controlling them with?
    The buttons for the device on the device management page?
    Try and capture a debug log in the plugin of the issue for me, log a help desk ticket on my site and attach the BLAB8SS-Detailed.log file.
    Cheers,
    Bob
      HSTouch and Events
        Post a screenshot of your event
        Cheers,
        Bob
          Here Are Two Different Events
            OK and they are not turning on and off at all?
            Turn on debug logging in the plugin and trigger one of the events and then disable debug logging. Put in a help desk ticket on my site and attach the BLAB8SS-Detailed.log file and I will have a look.
            I am at home today so try and get it to me ASAP.
            Cheers,
            Bob
              No luck with the support ticket so here you go
                Which device did you control?
                The log is quite large so knowing the device ref or code would help
                Cheers,
                Bob
                  Try 2.0.6 in the updater
                  I was able to control the speakers using the devices in events just like in your screenshot.
                  Worked here just fine
                  If still an issue then capture a new debug log (delete the old one first) and attach the new log zipped
                  Cheers,
                  Bob
                    Ok will let you know
                    Thom
                      Now neither will work at all
                        Tell what device was supposed to turn on and off?
                        Paste a screenshot of your devices from the dev management page. They should have an ON and OFF button and be owned by BLAB8SS
                        This is strange because no one else has reported this.
                        Mine is working perfectly here. I just controlled 5 of 8 speakers with no issues
                        Cheers,
                        Bob
                          Here you go
                            In your previous log I see no control at all for any of our speakers.
                            What happens when you click the ON and OFF button beside the device? Does it work?
                            If not then turn on debug logging, click on or off, then disable debug logging and attach the logged zipped. Make sure to delete the old log first
                            Try and get me the log as soon as possible so I can get this fixed today.
                            Cheers,
                            Bob
                              Bob,
                              I deleted the old log file, turned on debug file created 0kb, Turned the living room speaker on and off, turned off the debug and the log file is 119 MEG.
                              I tried this on 3 different rooms with the same results.
                              By the way it did not turn on or off
                              The Homeseer log had this over and over again
                              Jan-08 8:07:08 PM Error Calling HSEvent in plugin BLAB8SS, Instance :Object reference not set to an instance of an object. Jan-08 8:07:08 PM Error Calling HSEvent in plugin BLAB8SS, Instance :Object reference not set to an instance of an object. Jan-08 8:07:08 PM Error Calling HSEvent in plugin BLAB8SS, Instance :Object reference not set to an instance of an object. Jan-08 8:07:08 PM Error Calling HSEvent in plugin BLAB8SS, Instance :Object reference not set to an instance of an object.
                              BLAB8SS-Detailed
                              119 MB (125,501,440 bytes)
                              Thom
