Feedback/Issues
This is a sticky topic.
  • #46
    Try 1.0.12
    Cheers,
    Bob
    • #47
      YES!
      1.0.12 works.
      Thank you, Blade.
      Can you share what changed?
      • #48
        It apparently did not like the hex. I changed it to send a string
        Cheers,
        Bob
        • #49
          Originally posted by Blade View Post
          I am aware that some are missing.
          Can you confirm that all the commands in the plugin work ok?
          If so, I will add the MTRX command
          How's the MTRX command development for this plugin coming along? I have ordered an XAP800 and hope to be able to route audio input/ouput easily using HSTouch via this plugin.
          I'm assuming this can be done currently using scripts, but am hoping that this plugin via the MTRX command and devices will make it simpler.
          • #50
            Plus 1 for MTRX
            Trying out the plugin
            Plus 1 request for including the MTRX command as an event action.
            XAP800.
            I can/will probably work around it with by using Presets... but direct control over the routing via the MTRX command would be handy.
            Looks like a great plugin..
            Update... the presets seem to work well... and i probably don't need the "MTRX" command... just got to train myself to think a bit different than i did in the past.
            Andrew B.
            • #51
              I have not got the MTRX command done yet
              BTW I have a XAP800 I am selling if someone needs one
              Cheers,
              Bob
              • #52
                This plugin doesn't seem to have any documentation. I'd like to use this for whole home audio distribution rather than as a mic mixer. What I really want to accomplish would be to have the ability to choose source and destination options from HSTouch. So for example, I want to send music from input1/2 to output 1/2/3/4/5/6. Now I want to turn off output 5/6. Next I want to send input 3/4 to output 3/4/6/7. Would this plugin allow me to accomplish that? It seems like the MTRX commands are what I'd need is that correct? Any plans to finish that work?
                • #53
                  Correct, the MTRX command is what's needed to do that. Hopefully that will be released one day.
                  • #54
                    Will the MTRX Command be included in Event Action ?
                    • #55
                      Is the MTRX command part of this plugin now?
                      • #56
                        I will have to check and see if it got added - I cannot recall right now
                        Can u add a feature request on my web site for this and I will check and let you know
                        Cheers,
                        Bob
                        • #57
                          Request added. By the way, getting errors on a lot of pages on your server:
                          An error occurred on the server when processing the URL. Please contact the system administrator.
                          If you are the system administrator please click here to find out more about this error.
                          • #58
                            The MTRX command should be there if you are using an XAP800
                            Cheers,
                            Bob
