4300H
  • 4300H
    Hi,
    I'm trying to connect this plugin, in order to control my 4300H receiver.
    After entering the IP and port 23, I don't see the device appearing. What is the correct setup?
    I read somewhere that Heos supported receivers can be controlled using telnet only. Is it true? can this plugin control this receiver?
    Thank you
    Port 23 should be the one
    Do the following:
    1. Disable the plugin
    2. Edit hspi_BLDenon.ini and change debugLevel=true
    3. Save INI file
    4. Re-enable the plugin
    Once the plugin is started, disable debug logging
    Attach the BLDenon-Detailed.log zipped
    It is in the HS3 root folder
    Cheers,
    Bob
      Thanks for your fast reply!
      I hope you could help me, because I really want to buy Homeseer and use it
        Did you manage to examine the log?
          It looks like the plugin is creating the devices for the receiver
          Are you not seeing them in HS3 at all?
          Cheers,
          Bob
            Hi, thanks, it works now! great!
            When zone 1 is playing Spotify, and I change Zone 2 to Spotify (after turning it on) there's no sound though. I don't have any other Heos devices, so I can't tell if the plugin can control Heos.
