Issue with new version
    So, I updated all of my plugins from Blade (BLBackup, BLRfid, BLRadar, BLDenon) and as usual, needed to restart HS3Pro (3.0.0.398, Windows 10) for them to take. At startup, I got the following:
    6/7/2018 5:37:04 AM ~!~Error~!~Initializing plug-in(2): BLDenon Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()Startup Complete, 1 errors detected, check the log for more information.
    So, I decided to shut down HS3 and restart it. I did not get the BLDenon error, but I did get the following:
    6/7/2018 5:46:05 AM ~!~Error~!~Initializing plug-in(2): BLRadar Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    So, something is amiss with these updates.
    Elliott
    I have not seen this one before
    Looks like the error is coming from HS3 which is strange because the InitIO method was never changed in the any of the plugins
    Let me see if I can duplicate this when I update some of mine when I get home
    Cheers,
    Bob
      As far as I know, this might happen if a plugin process is already running and HS3 is trying to start another one.
        Thanks, all. I think I should reboot the computer and then see if the error comes up. I will do this later today and let you know. Elliott
          "Reboot and Rejoice"
          An old IT guy where I used to work used to tell us that if we had issues with our computer, before calling IT support, reboot your computer: "Reboot and Rejoice." So, he was right. I rebooted and rejoiced that the issue no longer exists.
          Elliott
            Glad to hear the reboot fixed it
            Cheers,
            Bob
