AVR-2313CI - How to control with serial?
  • AVR-2313CI - How to control with serial?
    Hi,
    My AVR-2313CI network adapter stopped working a long time ago. Now, I'm trying to control it from serial.
    In the BLDenon plunging page, I choose connection type RS232. The plugin keep asking me to enter an IP address...
    Is it possible to control my receiver with RS232? If yes, how?
    Stef
    When you pick RS232 it should let you put in the com port number
    Can you show me a screenshot of what you are seeing
    Cheers,
    Bob
      This is what I have:
      BTW, I'm using an iTach IP2SL configured as com 4.
        OK I need a debug log to see what is happening
        Do this first:
        https://forums.homeseer.com/forum/3r...-debug-logging
        Then do the following:
        1. Disable BLDenon
        2. Edit the hspi_BLDenon.ini and change debugLevel=true
        3. Save INI file
        4. Restart BLDenon
        Once the plugin has run for a minute or so turn off debug logging in the plugin options page
        Upload the BLDenon-Detailed.log zipped to my cloud
        https://nextcloud.btmaslen.com/index...sBzTCyz7g3cfeZ
        Cheers,
        Bob
          Done!
            I am seeing this in the log
            2018-08-22 19:21:29 : v2.0.52.0 - Connect_To_Denon_Receiver(): theMsg --> Error: Port in use
            Cheers,
            Bob
              Yes. I saw it also after uploading it to you. I'll try to find why.
                It's finally working. I had to configure it for TCP, not RS232. Thank you for your help!
                  No problem - glad you got it working
                  Cheers,
                  Bob
                    Hi Blade,
                    The Main zone is woking both way. But for zone 2, the plugin can control the Denon 2313ci but if power or source is changed from the remote, nothing happen in HS...
                    Is there something missing in the setup?
                      Capture a debug log of you changing the source from the remote and then give it a minute, then disable debug logging and attach the debug log zipped
                      Cheers,
                      Bob
                        Hi Blade, I've upload the log file. I did a few commands in that order: Zone2 power on, Zone2 input change to CBL/SAT, DVD, AUX and CD. After that I did a Zone2 power off.
                          I do not see the log attached
                          Cheers,
                          Bob
                            It's because I uploaded it to your site.
                              Yep sorry - forgot I gave you the cloud link (you are the only one that has it)
                              I see errors in your log
                              I will need to study the log and see what is happening
                              Cheers,
                              Bob
