First time user manual.
  • First time user manual.
    Where would I find information on how to activate the plug-in Including Set up in HomeSeer web control.
    You install the plugin from the HS updater. Once installed you will need to go to the Manage... Plugins web page and enable it
    Once enabled, you will need to go the web interface under Manage.... Plugins... BLDenon
    You can then go to the receivers page and add a new receiver by giving it a name, choose connection type (TCP or com port) and enter in the ip address and port number (23) or the com port number depending on the connection type.
    Once you add the receiver, the plugin will create HS devices for the receiver
    Give this a try and let me know how you make out
    Cheers,
    Bob
      Thank you , the port number 23 was the trick. Besides writing you where else is that info published?
        There is a help web page in the plugin but it is high level
        I really need to document a few plugins that require specific port numbers
        Cheers,
        Bob
