Heos Link?
  • Heos Link?
    I'm trying to test this with HEOS link. I'm not sure what port I'm supposed to use for the TCP port number. I've tried 23 and also 554.
    I would have thought that port 23 would work as it works with the other Denon receivers
    Try 23 first - If not, try port 1255
    Cheers,
    Bob
      Thanks, I'll try those. I was doing it remotely, so I can't test live. Is there any feedback as to weather its communicating to the device or if those are failing? I enabled logging, and don't see any errors in the homeseer logs...
        When you added a receiver it should have created devices for the receiver
        You can use those to control the reciever and they will update as well
        Cheers,
        Bob
          Ok, so if I set it to on instead of standby, if it looks like it works in the device list, that likely means its working?
            Looks like it is working
            Cheers,
            Bob
              Hey, can I take it from this that you got the HEOS Link working with this PI? If so do you have full integration?
              Many Thanks
              SImon
