Working with raw commands
  • Working with raw commands
    Hello,
    I try to start to use Homeseer and BLDenon plugin.
    I would like to use raw commands to change the HMI out status (HDMI 1 or HDMI2)
    the example command in the avr4308CI protocol is VSMONI1<CR> and VSMONI2<CR>.
    So I create an event I call Denon Moni 1, and inout the script:
    Dim theResponse As String = ""
    theResponse = hs.Plugin("BLDenon").SendRawCommand("VSMONI1")
    hs.writelog("Info", "The response for the command is: " & theResponse)
    theResponse = Nothing
    and for moni 2
    theResponse = hs.Plugin("BLDenon").SendRawCommand("VSMONI2")
    but I have an error in homeseer log and no change on the receiver.
    Thanks for the help!!
    What is the error?
    Cheers,
    Bob
      I think homeseer doesn't like the script in the help file.
      I put:
      Sub Main()
      Dim theResponse
      theResponse = hs.Plugin("BLDenon").SendRawCommand("PWON")
      hs.writelog "Info", "The response for the command is: " & theResponse
      End Sub
      and it works.
      When I put the last example:
      here is my error message:
      24/04/2011 19:41:11 - Error - Running script, script run or compile error in file: bldenon Moni2 test21025:Fin d'instruction attendue in line 2 More info: Fin d'instruction attendue
      I had activated the debug loggin in the BLdenon plugin options but I don't find the debug file... if you want, I can search it and send it.
        Are you using a vb.net script?
        I would recommend you use vb.net scripts
        Cheers,
        Bob
          I use the script editor included in homeseer web page.
          I don't think it uses vb.net.
          What should I do to be able to create vb.net script? Only change .txt extension in .vb?
            Yes the script needs to have a .vb extension.
            Paste in the script and I will convert it to .net for you.
            Hopefully the script is not too big
            Cheers,
            Bob
              Here is the scriptin vb, thanks.
              Sub Main()
              Dim theResponse
              End Sub
                Try this:
                Sub Main(ByVal parms As Object)
                End Sub
                Cheers,
                Bob
                  thanks,
                  I will try this code today.
                    I tried today and it worked well
                    Thanks a lot
                      OK So the plugin doesn't really work well with my receiver. I have a 3312Ci. However, the raw commands do work well. So I decided to create a script that I can pass commands to my receiver using the raw feature. I also wanted to create just one script where I can pass in parameters to whatever I want to do with the receiver. This is how I wrote the code.
                      Public Sub Main(ByVal parms As Object)
                      Dim DenonArray() As String = parms.ToString.Split("|")
                      Dim theComm As String = DenonArray(0)
                      Dim theStatus As String = DenonArray(1)
                      theResponse = hs.Plugin("BLDenon").SendRawCommand(theComm)
                      hs.WriteLog("Denon", "The Denon just: " & theResponse)
                      theResponse = hs.Plugin("BLDenon").SendRawCommand(theStatus)
                      hs.WriteLog("Denon", "Denon Confirmation Return: " & theResponse)
                      End Sub
                      And I pass in ("Main", "PWSTANDBY | PW?")
                      This for some odd reason doesn't work. What am I doing wrong? However, this works just fine.
                      theResponse = hs.Plugin("BLDenon").SendRawCommand("PWSTANDBY")
                      theResponse = hs.Plugin("BLDenon").SendRawCommand("PW?")
                      End Sub
                      I also did this to troubleshoot and see what the parms actually are.
                      hs.WriteLog("Denon", "The theComm parm is: " & theComm)
                      hs.WriteLog("Denon", "The theStatus parm is: " & theStatus)
                      End Sub
                      And I see that I am passing the right parms into the correct area. I also have added .ToString at the end of them and they still don't work. Any ideas?
                        What error do you get?
                        I assume this is for HS2
                        How about this:
                        Public Sub Main(ByVal parms As String)
                            Dim DenonArray() As String = parms.Trim.Split("|")
                            Dim theComm As String = DenonArray(0).Trim
                            Dim theStatus As String = DenonArray(1).Trim
                            theResponse = hs.Plugin("BLDenon").SendRawCommand(theComm )
                            theComm = Nothing
                            theStatus = Nothing
                        End Sub
                        Cheers,
                        Bob
                          The trim did the trick. Thanks so much!!! Your the best!!!. And yes I am using HS2. Also, FMI if I purchase the HS2 plugin, do I need to repurchase HS3 plugin?
                            No you should get a HS3 license for free if you purchase HS2 plugin.
                            Any HS2 plugin purchased after Oct 1, 2013 will get a free HS3 license
                            Cheers,
                            Bob
