Cursor volume in HS touch
    Hello,
    is it possible to have a cursor volume in homeseer gui designer?
    THX!
    slider
    this one is based on a slider in hst :
    Just make a virtual device that contains the slider value ( V15 in the example )
    Now the MasterVolume command can be ( if i remember right )
    MV00..90 ( so between MV34 or MV77) so limit your slider to the max value of 90
    now make a action in hst ( HomeSeer: Run a HomeSeer script with values from elements(s) )
    and put this line at the script
    &hs.Plugin("BLDenon").SendRawCommand("MV" & hs.DeviceValue("V15")&"")
    That should be it and triggers your mastervolume based on the value of device v15
      thanks,I will try that
