Trigger Events?
  • Trigger Events?
    How can I trigger an event based upon the powering on/off of the Denon? I would like the theater lights to slowly dim when the amp is powered on. Similarly, the lights will come up when Denon is turned off.
    The BLDenon devices do not support value or status change, only string changes.
    There is no trigger in the events drop down list for BLDenon.
    The best I can do is run a recurring script to check devicestring every minute. That really doesnt work out well.
    Am I missing something here or did you leave out triggers in your plugin?
    I guess I could use MyTrigger plugin which will do triggers on devicestring changes...
    http://forums.homeseer.com/showthread.php?t=143389
