Change Source status
  • Change Source status
    Hello,
    I try to change the source status of my denon avr4308. I changed the name of the sources in the receiver, for example: DVD is HTPC...
    It looks like that when I change the source using my script:
    Sub Main(ByVal parms As Object)
    Dim theResponse As String = ""
    theResponse = hs.Plugin("BLDenon").SendRawCommand("SIDVD")
    hs.writelog("Info", "The response for the command is: HTPC" & theResponse)
    theResponse = Nothing End Sub
    I don't have status change in the device status. I would like to have device status change to know wich source I have in my HStouch.
    Note: My avr is well controlled with this script and I have a log file saying I the info response.
    Thanks for help.
    The status can be change for power, volume, but
    For request power status:
    theResponse = hs.Plugin("BLDenon").SendRawCommand("PW?")
    hs.writelog("Info", "The response for the command is: " & theResponse)
    theResponse = nothing
    End Sub
    For Volume status:
    theResponse = hs.Plugin("BLDenon").SendRawCommand("MV?")
    End Sub
    FOr source status, it doesn't work maybe because the name was changed...
    theResponse = hs.Plugin("BLDenon").SendRawCommand("SI?")
    End Sub
      In fact, I tried to put back the default names of the input, but it don't change anything. Maybe the answer is different and bldenon don't understand them?
      When I put 3 scripts in the event with command
      DenonSrcAppleTV.vb
      theResponse = hs.Plugin("BLDenon").SendRawCommand("SITV/CBL")
      End Sub
      then
      DenonResSI.vb
      End Sub
      DenonResSV.vb
      theResponse = hs.Plugin("BLDenon").SendRawCommand("SV?")
      End Sub
      here are some kinds of answers in the log:
      23/11/2011 21:44:23 Event Running script in background: DenonSrcAppleTV.vb
      23/11/2011 21:44:24 Info The response for the command is:
      23/11/2011 21:44:41 Event Event Trigger "aadenonReqSV"
      23/11/2011 21:44:41 Event Running script in background: DenonReqSI.vb
      23/11/2011 21:44:41 Event Running script in background: DenonResSV.vb
      23/11/2011 21:44:42 Info The response for the command is: SVTV/CBL
      23/11/2011 21:44:42 Info The response for the command is: SITV/CBL SVTV/CBL
      the log info is ok with good audio and video input but no change in the status page...
        Incredibly, with HTPC (change name of DVD source) and vaux command, I have:
        23/11/2011 22:19:56 Info The response for the command is: SIDVD SVDVD
        23/11/2011 22:22:56 Info The response for the command is: SIV.AUX SVV.AUX
        and I have status change...
        with these one no change in status:
        23/11/2011 22:14:32 Info The response for the command is: SIHDP SVHDP
        23/11/2011 22:18:34 Info The response for the command is: SITV/CBL SVTV/CBL
        23/11/2011 22:22:08 Info The response for the command is: SINET/USB
        For this one it recognise svsiyrce but no sidvr
        23/11/2011 22:20:49 Info The response for the command is: SIDVR SVSOURCE
        Maybe the plugin doesn't understand these names?
          It seems that the plugin doesn't understand these entries to change the status: SIHDP, SITV/CBL, SINET/USB, SIDVR, SISAT, SIVCR
          It should be grat to add the status features for:
          -surround mode
          -HDMI Monitor out status
          -Cinema EQ
          -PS night mode
          -PS Mode
          -PS Room EQ
          -PS Restorer
