tenScripting issues with BLDenon: serialisation error
    I am programming scripts with tenScripting in Visual basic 2010. And got the following error:
    Type HSPI_BLDENON.HSPI+pair in assembly hspi_BLDenon, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null is not marked as serializable.
    Found following forum post with same error for BLRadar. Can you fix it also for BLDenon?
    http://board.homeseer.com/showthread...nscripting+dll
    I've received a support request from another user of tenScripting that received the same 'not serializable' error in referenceing the BLRADAR plugin from tenScripting.
    He contacted the author, who promptly supplied a revised plugin that WAS marked serializable per the HomeSeer standard, and all is well with referencing BLRADAR from tenScripting.
    This might be the solution for Squeezebox.
    tenholde
    Jan-Willem
