Tuner Frequency Adjustment
  • Tim.Kieschnick
    Other than some volume sliders on HSTouch, I find myself using SendRawCommand nearly all the time. I find that it is definitely worth learning the "Denon serial protocol" to control speaker configurations, surround modes and etc -- everything beyond simple power, volume, and source selection.
  • The-Source
    Yes you can set the frequentie directly, or set your tuner to a defined preset.
    The code for setting the preset is:
    actionset= "TPANB2" 'This set radio tuner to preset B2
    reply = hs.PluginFunction("BLDenon","","SendRawCommand", actionset) 'Response is current frequentie
    I use a script which i call with HStouch which passes the selected value of a listbox to this script. Offcourse this is not the complete script but you could work with this.
    As im now using the Denon for video i cannot give you the code for frequentie setting but that is documented in the rs232 document of Denon.
    edit: if you google for AVR-3808CISerialProtocol_Ver5.2.0a".pdf" you should be able to find it.
  • sparkman
    Originally posted by Ramymounir View Post
    why are most of the posts here unanswered?
    Blade, the plugin author, has his own help desk portal. I'd suggest creating a ticket there: http://bladeplugins.no-ip.org/helpdesk/Login.asp. He's very responsive through that method.
    Cheers
    Al
  • Ramymounir
  • EdinTexas
    started a topic Tuner Frequency Adjustment
    Is it possible to adjust the FM tuner frequency?
