I am not sure what i'm doing wrong. or what I'm missing. Can someone help? When I run this script (AVRDVD.vb):
Sub Main(ByVal parms As Object)
Dim theResponse As String = ""
theResponse = hs.Plugin("BLDenon").SendRawCommand("SIDVD")
hs.writelog("Info", "The response for the command is: HTPC" & theResponse)
theResponse = Nothing
End Sub
I get this error:
Scripting runtime error: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. --- System.NullReferenceException: Object variable or With block variable not set. at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ct or(Object Instance) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at scriptcode15.scriptcode15.Main(Object parms) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) at Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
End Sub
I get this error:
