HS3 conversion
  • #16
    Capture a debug log of it not working and attach the BLDenon-Detailed.log zipped here
    Cheers,
    Bob
    • #17
      Script ran 14:47:16 and 14:47:28 according to the HS log.
      • #18
        OK I will have to check into this. I have a denon receiver at home. I just need the time to test it out and see what is going on
        Do you have a ticket in on my site for this?
        Cheers,
        Bob
        • #19
          Yes, I do. See ticket #0000553.
          • #20
            I'm finally back from vacation, and can start working on things that really matters again.
            bladeplugins.no-ip.org is down, so I'll post the log file you requested here.
            I still see the same thing: "MstrPower" does nothing.
            Everything else works (and with the latest version it is much more robust it seems, kudos!).
            Here's what I did:
            - Enabled logging
            - Pressed the MstrPower buttons
            - Pressed Zone 1 Mute/Unmute buttons.
            - Disabled logging
            • #21
              Web site should be up now.
              Please attach the log zipped to the ticket so I can track it better. I will have a look at it as soon as I can
              Cheers,
              Bob
              • #22
                Here's what I did:
                - Enabled logging
                - Disabled logging
                Have you tried deleting the MstrPower devices for all receivers in HS3 and then restarting HS3 to let BLDenon recreate them.
                Then try it again and let me know
                Cheers,
                Bob
                • #23
                  I tried that in a different way. I removed the amp from the BLDenon settings, deleted all devices, and added the amp again.
                  This should do the same thing, yes?
                  • #24
                    Try 2.0.17 in the HS3 updater and let me know
                    Cheers,
                    Bob
                    • #25
                      YES!
                      It works!
                      Thank you so very much for all your help with this!
                      • #26
                        No problem. Close the ticket on my site please.
                        Cheers,
                        Bob
